Which direction to go with modding!
Old Jan 29, 2010 | 06:23 PM
danieluf's Avatar
I have saved up a little bit of money but have no idea which direction to go with my modding.
When I purchased my car the stock rims already had the typical scuffs around the outside from when the previous owner had hit a curve or two. Not too many people even notice it but it bothers me from time to time and I know that eventually I want to replace them with a nicer setup.
I dont really plan on taking my car to the track or anything(at least anytime soon) because my car is my daily driver. That being said, I do enjoy having a quick daily driver that I can open up every now and then. My current mods are in my sig so what would you do? Any opinions will be appreciated.
option 1: ottp stage 2 or zzp stage 3
option 2: new rims (Im thinking either msr 045's in black with the polished lip or motegi sp5's in black with polished lip)
Old Jan 29, 2010 | 08:05 PM
Viceversa10's Avatar
the zzp from what i've read and seen puts out more power. I was in a similar situation that your in and it ended up with me going with the zzp stage 3 kit. I would suggest not going lower than a 2.8 pully and getting the stage 2 belt instead of the pully tensioner and getting the upgraded stage 3 front mount. All in all you should be around 260-270 whp. My car is also my daily driver (i use 93 octane) and around tower i get about 27 mpg highway 35ish but then again im also from the northeast so you'll prolly see a bit different numbers.
Hopefully you'll reach a decision soon. hope this helps.
Old Jan 30, 2010 | 12:40 AM
danieluf's Avatar
did you get the tensioner pulley when you purchased the stage 3 from zzp? I already have the stage 2 belt since my car already is GM stage 2 but they said that I should prob get the tensioner pulley because the kit may cause some belt slip without it.
Old Jan 30, 2010 | 10:31 AM
danieluf's Avatar
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
importkiller
Sep 30, 2015 07:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
