disable auto lights?
Old Mar 4, 2007 | 08:05 PM
SKDR112888's Avatar
I pulled the fuse on my DRL so my projectors bulbs dont keep burning out! I have an 07 with projectors
(the 07 models have the low beams on as DRLs)
now I want to disable the auto light featrure were if its dark enough outside the headlights automaticaly come on,
I did a search and came up with nothing useful,
can anyone help me? anyone with any ideas?
shane
Old Mar 4, 2007 | 08:07 PM
dervin3's Avatar
you mean you want them to be turned on manually? Just read the owners manual lol.
Old Mar 4, 2007 | 08:09 PM
SKDR112888's Avatar
yes I want them to be utned on manualy, I lost my owners manual, lol
I want to be able to have to turn my lights off an on by myself
Old Mar 4, 2007 | 08:12 PM
dervin3's Avatar
well I have an 05 and I don't know the differences but on mine, the lever to the left of the steering wheel you just flick it back towards you and it will say auto lights disables in the DIC
Old Mar 4, 2007 | 08:14 PM
SKDR112888's Avatar
no I want it permentaly off I know how to do that, and on the DIC it says auto lights tunred off, I know, lol
I want them permantly off, like an old car you have to turn the headlights on and off with your hand, all the time, how do I fix it to do that?
Old Mar 4, 2007 | 08:17 PM
calchr2's Avatar
im not sure that is possible? dont quote me on that though. i think its programmed into the body computer. although it would be interesting to find out if it could be done
Old Mar 4, 2007 | 08:42 PM
Jackalope's Avatar
Not sure it can be permenently turned off but just turn the headlight switch backward when you start the car that shuts off the auto light feature. Flipping that little switch really isn't that hard. I do it every day.
Old Mar 4, 2007 | 08:51 PM
SKDR112888's Avatar
yeah but wouldnt it be soo much nicer not to have to flip that switch! lol
Old Mar 4, 2007 | 08:54 PM
SSSC's Avatar
Maybe find a way to rig up the sensor located on the dash. Take apart and ground the wires maybe?
Make it tell your computer it sees light even when it dosen't.
Old Mar 4, 2007 | 08:59 PM
Coblasts's Avatar
Maybe you could get a hold of the manufacture and find out why they arte burning out prematurely.
May you have the wrong model no. for the Cobalt ,somthing simple like that.
Old Mar 4, 2007 | 09:04 PM
SKDR112888's Avatar
thats a good idea, Ill look into that and see how it works
Old Mar 4, 2007 | 09:05 PM
YellowCobaltLT's Avatar
shane
Hi guys i have the same question(permanently turn off auto lights). I have a set of projectors coming and i also have an 07. I am going to be putting hid's in the projectors and i don't want them on all the time. Am i correct in thinking that the lows would be on as the drls? or would the highs be on for drl's? Thanks!
Old Mar 4, 2007 | 09:48 PM
fastss25's Avatar
With some cars you can use a tech 2 and disable them that way. But, I don't own a tech 2 and my buddy sold his so I don't have access to try that. If anyone knows someone at a dealer I would say head up there and check it out and let us know. I want to disable mine too for an 07.
Old Mar 5, 2007 | 08:43 AM
SKDR112888's Avatar
to disable the DRLs you pull the fuse under the hood, and the DRLs will never come on agian, (unlessy you put the fuse back in) and on the 05-06 the parking lights are the DRLs, and on the 07s its the low beams as the DRLs
but agian, I want to knowhow to disable the auto light feature, so that I turn the headlights on and off not the car automatical, lol
Old Mar 5, 2007 | 09:08 AM
Ok thanks. How about if you put a switch for the whole light system and just flip it on at night? That might do what you want and would probably be fairly easy. Do you know if I could wire the projectors so that the drl's are the high beam bulb? Thanks
Old Mar 5, 2007 | 09:24 AM
ItalianJoe1's Avatar
You can't disable the auto lights to my knowledge. I tried using the tech 2, you can't change anything with the auto lights. There was no procedure that I found to disable them. If they really bother you, just shut them off, thats what I did. Eventually I stopped caring, and just leave the little orange corners on anyway, no matter how stupid they look.
Old Mar 5, 2007 | 09:27 AM
I actually like the orange corners but on the 2007 they don't lite up as the drl's.
Old Mar 5, 2007 | 09:39 AM
neodude101's Avatar
I like the orange corners, too. I always like driving up behind a semi (you know the ones that have reflective backs on em) on the interstate and seeing it glowing orange, or catching the reflection of them on a building's windows.
The orange DRLs are actually one of the first things i look for when spotting balts (especially from a distance). I'm always disappointed when I see what I think is a Cobalt approaching, but then the glowing orange turns out to be the DRLs of one of those ugly ass new Malibus...
Old Mar 5, 2007 | 01:06 PM
SKDR112888's Avatar
so on one has tried to ground out the snsor or jump those 2 leads together or anything? lol
Old Mar 5, 2007 | 01:21 PM
Well if there are only 2 leads going to the sensor, then if you connected them it would probably be like there was constant sunlight. But i don't know for sure?
Old Mar 5, 2007 | 01:25 PM
SKDR112888's Avatar
thats what I was thinking, just wondering if anyone eles has tried that?
Old Mar 5, 2007 | 01:31 PM
Super_SS's Avatar
take the day light running fuse out...it should be in the engine bay..that automatically disables the day lights..they wont turn on until u actually turn the levler to ON OFF
Old Mar 5, 2007 | 01:41 PM
Doc's Avatar
Doc
The Tech2 is able to do this. The reason I know, is I couldn't get my dash lights to come on when I turned on the lights manually. Anyway, there is a setting to disable the drl's. The tech did this in an attempt to get my dash lights to come on when I manually turn on the headlights (it didn't work). It is a huge safety concern (cobalts get a discount for DRL's) and I am not sure how many dealerships will condone you turning off a safety feature.
Now, if you had a buddy, he might be able to turn them off for you.
When I get home tonight, I'll post the different computer settings (for the vcm) from before to after to give an idea which controller handles the lights.
Old Mar 5, 2007 | 01:49 PM
SKDR112888's Avatar
lol OMG!!
I have the DRLs disabled, I just pulled the fuse! I DOnt need to have these disabled, everyone keeps telling me how to do this and I dont need to ! I already have it done,
I want the headlights soo there not automatic, so I have to manualy turn the lights off and on, not if its too dark they come on automaticaly, lol
so NO MORE DRLs comments, I know all about them!! More than I want to know! lol I know there a safety feature, and its illegal to disable them and yeah....
How do I disable the automatic headlight feature, were if its dark they come on automaticaly, and when its light out they stay off, lol soo far all I have is to jump those 2 wires going to the sensor together, and like DOC said get into the computer and do it there, I want to be able to turn the switch anytime night or day and the head lights and the dashlights come on. lol
Old Mar 6, 2007 | 03:58 AM
Jackalope's Avatar
This seems like a lot of work to just save one second of your day by flipping the switch.
::::shrug:::: Maybe its just me but aren't you wasting more time trying to disable them then you could ever spend turning the headlight switch backward?
Oh well best of luck, I guess.
