Do you have any rust?
I have one tiny rust spot on my hood where a rock chipped the paint off and another spot by the bottom of the passenger side door but besides that no rust problem especially being in upstate New York
This thread is useless with out Pics
i mean a rock chip size rust spot opposed to a door panel spot is a big difference i wana see what you guys are talking about when you say its got rust.
every time i see primer showing from a rock chip i hit with some touch up paint ... call me ****
i mean a rock chip size rust spot opposed to a door panel spot is a big difference i wana see what you guys are talking about when you say its got rust. every time i see primer showing from a rock chip i hit with some touch up paint ... call me ****
How the hell does that even happen, that happened on my car as well in several spots. UNDER the original paint, and it was not rusting through from the opposite side, it was like it was there on the panel when they originally painted the car.
Correct. There is some touch up paint I tried to apply when I seen the chips. but it is bubbling up from underneath and if you peel it off, there is rust.
Mine is rusting beneath the paint, like something between the sheet metal and started rotting from inside out.
Zero rust on mine. Not even on the under body. Not driven during winters. the cars only really see water when being washed. I use a detailing blower too remove any water from hard to reach places.
This on both doors, driver side quarter lip beginning, rocker panel lip beginning. There's also rust on the front subframe but that's technically only bolted to the body so that's not included. Same with strut mounts, shocks, exhaust, etc.
I should probably undercoat my car... i have a biit of rust mostly where the doors rub and some around the jack points stuff like that nothing big yet though.
Don't undercoat it. It'll rust twice as fast trust me. GM and a lot of new car manufactures advise against it for a good reason. Unless you can degrease everything and use a paint prep solution to get rid off all moisture id just leave it alone and keep it clean.
