Does adding power mods=less gas mileage?
Old 10-26-2005, 05:54 PM
BlackS/C's Avatar
If you have a super or turbo charged car and add power mods like stage 1,2, or twin charged kit(I know it's not out yet just asking)or bigger s/c, t/c, will your gas mileage go down? Keep in mind that I am new to modding and F/I cars.
Old 10-26-2005, 05:57 PM
Cobalt30's Avatar
im guessing yes since there is forced induction causing more gas to be dumped in the engine to support the air ratio mixture.
ryan
Old 10-26-2005, 06:03 PM
UtOhCop's Avatar
Yes it will go down
Old 10-26-2005, 06:14 PM
SilverSS/SC's Avatar
Adding things that promote effciency will actually net you a little gain in mileage . Things like a cold air kit , cat back , high flow converter , ignition box ect. Adding more boost though , with bigger injectors is gonna ding ya a bit . Couple stage 2 with a cold air and a cat back and mileage probably will not suffer toooo much . GM's PCM tune is still gonna be on the conservative side of things rather than for max performance with the staged kits .
Old 10-26-2005, 06:40 PM
Proud Playstation 3 Owner
philco_3's Avatar
lets hope
Old 10-27-2005, 12:15 AM
urbanmonkeygod04's Avatar
Don't forget, GM's stages come with upgraded fuel injectors - more fuel into your engine should immediately tell you that you're going to use more fuel up. I'd field a guess that on the highway cruising you'll probably only notice a 1-2 mpg drop, but if you romp on it everywhere, you'll be looking at awful mileage, like Lamborghini Diablo or Dodge Ram HD mileage. Any SRT guys with the staged upgrades want to chime in here? I know the Mopar kits also come with bigger fuel injectors.
Slightly off-topic, on an eight-pass trip to the drag strip I used up 2 gallons of gas, so I only got 1 mpg!
Old 10-27-2005, 12:28 AM
Domestics Pwn
ExHondaMan's Avatar
More Fuel and Air = More Power... Of course if properly tuned the MPG loss should be minimal when just cruising and even in a lot of part throttle situations.. But I would guess for most people the more power your have.... The power your foots into the peddle ... when definitely means your MPG will drop...
Old 10-27-2005, 08:46 AM
Nightcrawler's Avatar
Yes, I would say you won't notice decreased mileage under non heavy throttle situations.
You can have giant fuel injectors, but if the throttle isn't open, it's not going to matter.
As always, it heavily depends on how you drive. Increased power means your car has the POTENTIAL to guzzle more gas, but it depends on what you do with that potential.
Old 10-27-2005, 09:52 AM
codyss's Avatar
Well with my other car 2002 Camaro SS and my previous 2003 Mustang GT mileage went up with certain modifications.
The most noticable mileage increase on both cars came after re-flashing the ECM.
As for the SS/SC it is really no different, unless you are WOT all of the time the bigger injectors and boost won't make a difference. As for the re-flash it will most likely increase MPG.
With a piggy back unit and pulley you will most likely see a MPG decrease due to the fact that it is playing with ECM input readings to make up for more boost.
Old 10-27-2005, 10:03 AM
memphisr24's Avatar
It will go down, since when you get those mods, You will want to test them out
Old 10-27-2005, 10:42 AM
LMDRIVER's Avatar
Gas Milege
Yes your gas milege is going to decrease. But how much depends on what mods you do.
Zharrington_2010LNF
02-08-2016 01:43 PM
RaginChopsuey
10-27-2015 01:27 PM
biniecki
10-25-2015 02:23 PM
Stuff
10-01-2015 05:47 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: Does adding power mods=less gas mileage?
