Engine help
Old Apr 19, 2012 | 10:52 PM
ingram57's Avatar
Engine help
How hard is it to pull a LNf out any tips and tricks
Old Apr 19, 2012 | 10:59 PM
ingram57's Avatar
Bump bump
Old Apr 20, 2012 | 02:39 AM
cobalt5SS's Avatar
why
Old Apr 20, 2012 | 08:27 AM
ingram57's Avatar
Cause if my car dosent get covered by warranty I need to rebuild my motor
Old Apr 20, 2012 | 10:44 AM
bluebalt07's Avatar
Most likely it would be easier to get a lift, unbolt the cradle, and take the body off the cradle instead of the motor out of the car.
Old Apr 20, 2012 | 12:40 PM
cobalt5SS's Avatar
not sure about the lnf but lsj was designed to drop from the bottom. I would imagine it to be kinda the same.
Old Apr 20, 2012 | 09:59 PM
Malaclypse's Avatar
Having replaced both an LSJ in a Cobalt SS and a 2.2 in an Ion, I can say that they're much easier to drop out of the bottom. There just isn't alot of wiggle room in the engine bay.
Old Apr 20, 2012 | 11:14 PM
ingram57's Avatar
Thanks how hard is it to drop it out the bottom haven't really looked at it I have a lift and everything sooo
Old Apr 21, 2012 | 02:59 AM
FasterIsBetter's Avatar
Engine hoist/crane or tranny jack if you have a lift or even if you don't. Very easy to drop. I was able to drop mine by myself and slide the entire subframe out. I had help putting the subframe/engine back in though. I would recommend help to watch for you to get the bolt holes lined up for the mounting locations on the sub frame. With airtools, I had the subframe back in the car in less than a half hour.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
