Engine and Tranny mounts
Old May 31, 2008 | 05:01 PM
dsp86's Avatar
I want to get some urethane engine and tranny mounts for my 07 cobalt ss 2.4.Any one have any suggestions and where is a good place to get them from. thanks.
Old May 31, 2008 | 05:08 PM
Red2.4SS's Avatar
Get em from Turbo Tech Racing! Woot!
Old May 31, 2008 | 05:09 PM
Superman_Davin's Avatar
search button shall be your friend...
http://turbotechracing.com/productca...idproduct=4933
found this in 10 seconds
Old May 31, 2008 | 06:28 PM
TurboTechRacing's Avatar
As long as you have a manual tranny it will work perfect (with an aftermarket intake like Injen)
Also if members have an automatic tranny, and want an solid upper enigne mount, we will have them shipping is about 2 weeks YAY! Design is complete they are in manufacturing now....
Old May 31, 2008 | 06:29 PM
SI FTL's Avatar
whats the reason behind aftermarket engine/tranny mounts? just wondering
Old May 31, 2008 | 07:43 PM
dsp86's Avatar
they reduce the movement of the engine and tranny by doing that u get a faster transfer of torque cuz ur engine isnt moving.same idea as a torque dampener.
Old May 31, 2008 | 08:50 PM
Also it eliminates/reducing "wheel hop", in addition as stated maximizes the torque transfered to the wheels.
Old Jun 1, 2008 | 12:35 AM
SI FTL's Avatar
really.. hmm my cobalt has madd hopps Maybe i should look further into this..
Old Jun 1, 2008 | 01:23 AM
BoostedG5's Avatar
Wheel hop is a great way to bend your car over and **** it till it bleeds. Get the mounts...
Old Jun 1, 2008 | 09:06 AM
Good way to put it. Without Solid mounts you get wheel hop; Which can be so bad it will crack your tranny case open.....
Old Jun 1, 2008 | 11:15 AM
SI FTL's Avatar
I found the tranny mounts on turbotech. but as fasr as engine mount goes, upper mount or just a torque dampener?. Do the tranny mounts reduce wheel hop or is it a combo with tranny and engine mounts
Old Jun 1, 2008 | 01:09 PM
BoostedG5's Avatar
you should typically get both so they both set at the same time and you only have bad vibes for a couple days instead of having bad vibes on 2 seperate occasions. The upper mount is what you want, in the very essence of the mount it is a torque dampener. Plus it looks purdy 8).
Old Jun 4, 2008 | 05:45 PM
Exactly.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
