A/F Install Question
Old Jul 10, 2006 | 03:28 PM
Blackout06LS's Avatar
At work so a bay is tied up right now. I have two white, grey, and a black wire on the rear o2 sensor. My grey wire is the signal wire that I hook up to my gauge correct?
Just really want to get it done before I leave work today.
Sorry if this is a re. HowTo will come later on when I hook up my oil pressure.
-Eric
Old Jul 10, 2006 | 03:32 PM
powerbalt4020's Avatar
i would like to know also. im getting an autometer wideband a/f gauge with the O2 sensor. i dont know a damn thing about hooking it up.
Old Jul 10, 2006 | 05:52 PM
BUMP...I just let it go for the day. Wanted both my bays back open lol.
Again...BUMP!
Old Jul 11, 2006 | 07:17 AM
denniss's Avatar
GM manual shows
Heated Oxygen Sensor (HO2S) 1 Pin
Wire Color
Circuit No.
Function
A
TN/WH
3111
HO2S Low Signal sensor 1
B
PU/WH
3110
HO2S High Signal Sensor 1
C
GY/WH
3113
HO2S Heater Low Control Sensor 1
D
PK/BK
5291
Ignition 1 Voltage
Heated Oxygen Sensor (HO2S) 2 Pin
Wire Color
Circuit No.
Function
A
TN/WH
1669
HO2S Signal Sensor 2
B
PU/WH
1668
HO2S High Signal Sensor 2
C
PK/BK
5291
Ignition 1 Voltage
D
GY/WH
1423
HO2S Heater Low Control Sensor 2
Don't know why you only have 3 wires, should be 4.
Also don't know which one you should use.
This is a 2006 2.2?
Dennis
Old Jul 11, 2006 | 07:23 AM
I have four....two solid white, one grey, and one black.
Yes 06 2.2L.
Sucks only having access to DaimlerChrysler products at my dealership.
Old Jul 13, 2006 | 02:57 PM
When installing this wideband O2 gauge with a wideband O2 sensor...where do you install the sensor?
http://autometer.com/cat_gaugedetail...id=3603&sid=15
Old Jul 13, 2006 | 03:28 PM
denny's Avatar
You have to drill out a hole on your exhaust before the Cat. converter. Install a bung (have to get it welded) and screw in your o2 sensor. Done.
Old Jul 13, 2006 | 06:14 PM
06blackg85ss's Avatar
puttin my aem in tomorrow... I"ll post some pics
Old Jul 15, 2006 | 03:41 PM
Well just did the install...after countless tries trying to find someone who knew which wire specifically for the 2.2L(Chevrolet I mean). I installed it and its working.
My A/F ratio is probably around 13:1 or close to that. It's two light brown bars above the two green(rich) under WOT conditions.
I found the wire close to the ECU...its a purple wire with a white stripe.
Old Mar 30, 2007 | 10:56 PM
stvn's Avatar
and what about for the 2.0l
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
Bohb
Sep 27, 2015 09:11 PM
