A few questions if I may...
Here are 3 questions I am looking for answers on as far as performance parts.
1.) If I where to buy a tune from someone w/ the same mods as me, and he worked out his A/F would it carry over to my car, or does that vary car from car?
2.) I dont have to keep a wide band in 24/7 right? I can tune to the right levels and take it out and call it a day. I have a Interceptor and get 0 knock.
3.) What are the Vibrations from an engine mount like? If you put antivibration tape on it before installing would you still get the +'s of a solid mount, w/ less Vib?
1. It varies from car to car.
2. Not sure on that one.
3. I have the ZZP Billet Engine and get a good bit of vibrations, they did wear off as they broke in and got older, but they are still there. If your looking to nearly kill wheel hop, I would recommend it along with the tranny mount. To me, little no wheel hop and mild vibrations is worth it.
Hope that helps a little bit.
1. I have to say yes, it would transfer nicely. Like you said, you have all the same stuff he does.
2. Correct, you don't need to keep the wide band installed after you have finalized your tune.
3. I don't know what anti-vibration tape is, but if doesn't sound like a very good way of solving such a problem.
Originally Posted by zinner
GM ships the same tune with all the SS/SC's
IF you have the same components they same tune will work.
IF you have the same components they same tune will work.I think Ill get HPTuners and get the tune from teh dood w/ stage 2 and 2.8, as well as intake/header/exaust. I mean its a different, header/intake and exaust but that shouldnt matter right
Iceberg
Sep 29, 2015 12:33 PM
