firewall heatshileding necessary?
Old Mar 16, 2008 | 02:29 PM
mike25's Avatar
just wondering if the black padding is really that necessary? i tore mine off for the tubro
Old Mar 16, 2008 | 02:34 PM
tru2nrtt777's Avatar
Just letting you know within the last 2 weeks there has been atleast 4 threads on it, It is only nessisary if you want to keep your underhood paint from messing up.
Old Mar 16, 2008 | 10:35 PM
mike25's Avatar
no not the underhood.....the firewall...
Old Mar 16, 2008 | 11:30 PM
Sufu's Avatar
I think it's called firewall for a reason.
Old Mar 17, 2008 | 11:19 AM
n8g's Avatar
n8g
Sound deadening, perhaps?
Old Mar 17, 2008 | 12:14 PM
LopsidedJester's Avatar
i bet it helps deaden sound, i ripped mine out and i think since now it is just a metal firewall all of the noise from the back of the engine and header just reflects down and out instead of being absorbed.
Old Mar 17, 2008 | 02:21 PM
firedude71_60's Avatar
It's also there for a reason!!!
Old Mar 17, 2008 | 03:03 PM
Sergio's Avatar
I'm sure it helps to deal with the extreme heat from the exhaust manifold and down pipe .
Old Mar 17, 2008 | 03:05 PM
redlineblueline's Avatar
itook it out on my 2.2 with no problems
Old Mar 17, 2008 | 04:03 PM
Just so we all are on the same page...
You removed your firewall! Not the underhood heat sheild! correct?
Old Mar 17, 2008 | 04:29 PM
mike25's Avatar
wow....nOobZ....i took off the heatshielding on the firewall...nevermind though i checked today after a half hour of driving and it was cool to the touch
Old Mar 17, 2008 | 06:48 PM
montecarloman's Avatar
How bout letting your car idle for an extended period of time after that 30 min drive? I'm willing to bet it was originally intended to protect the components behind the firewall from heat in a heavy traffic situations.
Old Mar 17, 2008 | 07:15 PM
mike25's Avatar
well that is possible...but i dont have that problem...i live in a quiet area i guess you could say....anyways even after driving 30 mins i see some heavy loads on the engine...i would guarantee if its not going to put off some heat after that and make it hot then its not going to at idle...no matter ill just buy some heat wrap and recoat the wall afterwards...the black part serves no purpose...just to hide the shiny heat shielding
Old Mar 18, 2008 | 01:37 AM
VibrantCOBALT's Avatar
wait. i dont have the firewall connected to the hood anymore.. that bad?
Old Mar 18, 2008 | 10:09 PM
mike25's Avatar
no you got it wrong....the firewall is the section of metal between the cabin and the engine bay...at least thats what ive always been led to believe.....the black stuff on the bottom of the hood and back of engine bay is just heat shielding
Old Mar 18, 2008 | 10:11 PM
Brian MP5T's Avatar
If the turbo is so close that you had to remove it, the turbo is close and I believe that you should try to place some sort of heat deflector up..
Old Mar 19, 2008 | 04:25 PM
mike25's Avatar
i removed mostly just to make sure there wont be any fitment issues when it goes to the shop on monday to have the dp made...i havent hadf a chance to test fit it yet and im just trying to clear paths...but i do plan on re insulating with some heatshielding
jojot001
How to Guide
54
Jan 11, 2009 08:30 PM
TheSikhest
May 1, 2008 11:06 PM
chomponthisdave
Nov 18, 2007 12:47 AM
ExHondaMan
How to Guide
29
Aug 8, 2006 07:36 PM
