Front brake shields
Front brake shields
Has anyone installed the front, inner brake shields? They weren't installed from the factory but were later suggested as a preventative measure in a TSB regarding uneven inner pad wear, pedal vibration and rotor warping.
I bought some to install when I do the hub/brake swap. Just curious to know if anyone has them on and if they've made any difference.
Not sure if that applies to the LNF but they are recommended for the other 5 lug models. There's two different sizes. I'll take pics of the shields when I get home from work.
, Brake Pulsation, Front Brake Inner Pad Wear (Replace Front Brake Pads and Add Splash Shields) - (Jul 21, 2008)
Subject: Front Brake Noise, Brake Pulsation, Front Brake Inner Pad Wear (Replace Front Brake Pads and Add Splash Shields)
Models: 2005-2008 Chevrolet Cobalt (Excludes SS Models)
2006-2008 Chevrolet HHR (Excludes SS Models)
2006 Pontiac Pursuit (Canada Only)
2007-2008 Pontiac G5
This bulletin is being revised to clarify the vehicles involved in the model and parts information. Please discard Corporate Bulletin Number 08-05-23-003A (Section 05 -- Brakes).
Condition
Some customers may comment on a brake noise and/or pulsation on brake apply. This condition can be more frequent if the customer resides or travels on dirt/gravel roads and usually occurs within 11,300 km (7,000 mi) to 16,000 km (10,000 mi) intervals.
Upon investigation, the technician may find that there is considerable difference between the front brake outer and inner pad thickness.
Cause
This condition may be due dust, dirt, and debris intruding between the inner brake pad and rotor.
Correction
Road test the vehicle and confirm that the brake noise and/or pulsation is coming from the front brakes. If it is determined that the noise is coming from the front brakes and there is a measurable difference between the outer and inner pad thickness, remove the front wheel bearing/hub assembly following published SI procedures, remove the bearing/hub-to-steering knuckle spacer and replace the spacer with a splash shield on each side.
Replace the front brake pads and follow the procedures outlined in Service Bulletin 00-05-22-002J for servicing the disc brake rotors.
Parts Information
Part Number
Description
Model
Usage
25884778
Shield, Front Brake (RH)
HHR
(EXC SS)
All
(EXC JL9)
Cobalt/G5/Pursuit
(EXC Cobalt SS)
w/ JL9 (level 3) (296 mm rotor)
(EXC JL4)
25884779
Shield, Front Brake (LH)
HHR
(EXC SS)
All
(EXC JL9)
Cobalt/G5/Pursuit
(EXC Cobalt SS)
(EXC JL4)
25931624
Cobalt/G5/Pursuit
(EXC Cobalt SS)
w/ J41 or
JM4 & PFD/PG1 or
JM4 & NZ0/NZ6
(level 0, 1 & 2) 256 and 280 mm rotors)
25931625
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
H9730*
Replace Front Brake Pads and Add Splash Shields (Inc Refinish Rotors)
2.2 hrs
*This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide
Condition
Cause
Correction
Parts Information
Part Number
Description
Model
Usage
25884778
HHR
(EXC SS)
All
(EXC JL9)
Cobalt/G5/Pursuit
(EXC Cobalt SS)
(EXC JL4)
25884779
HHR
(EXC SS)
All
(EXC JL9)
Cobalt/G5/Pursuit
(EXC Cobalt SS)
(EXC JL4)
25931624
Cobalt/G5/Pursuit
(EXC Cobalt SS)
w/ J41 or
JM4 & PFD/PG1 or
JM4 & NZ0/NZ6
25931625
Labor Operation
Description
Labor Time
H9730*
2.2 hrs
i know this says excludes SS models but there are 2 different splash shields. one for 296mm and one for 256/280mm rotors. Doesn't the LSJ have 296mm rotors?
I am putting on the LSJ/JL9 brake system. I bought the ones for the 296mm rotors. they were under $5 a piece. if they dont end up fitting/working, oh well.
n20saturn
Sep 30, 2015 12:26 AM
