Fuel additives?
Fuel additives?
Just wondering, is there any fuel additives I could/should be adding every so often? '10 SS here. I was thinking fuel injector cleaner but its direct injected so thats a no I'm guessing? I'm just looking to do everything I can to make this beast last as long and well as possible! Thanks for any replies
you can do all of that... but its a 2010... im not sure you need it... and if you do anything like that, your not going to see much of a difference...
but once every other month i do go to the advanced and pickup the fuel injection cleaner thing... yellowish, 6 dollars...
GM's recommendation on fuel additives for the 2010 Cobalt is as follows:
"To help keep fuel injectors and intake valves clean, or if the vehicle experiences problems due to dirty injectors or valves, look for gasoline that is advertised as TOP TIER Detergent Gasoline. For customers who do not use TOP TIER Detergent Gasoline regularly, one bottle of GM Fuel System Treatment PLUS, added to the fuel tank at every engine oil change, can help clean deposits from fuel injectors and intake valves. GM Fuel System Treatment PLUS is the only gasoline additive recommended by General Motors."
I hope this is helpful for you,
Sarah
GM Customer Service
Sarah
GM Customer Service
Everyone up to this point has said to keep fuel additives away from the direct injection engine in the 08-10 SS.
At that pressure you see no benefit.
Also, the fuel doesn't pass over the intake valve so you get no benefit there.
HUGE waste of money.
Therefore disregard Sarah's post all together.
I was trying to think of a caveman quote, but I got nothing.
Shell advertised that their gas will clean the valves on DI engines too. Better tell them their ad is wrong too. No fuel isn't going over the valves but I'd guess that both companies have smart enough people to know something we don't.
As for saying: good marketing= smart Shell engineers. That's a bit naive.
for all you guys saying the DI motors don't need this, just because it may not touch the valves or anything like that doesn't mean the additives don't keep your fuel filter cleaner and your fuel lines cleaner as well.
just saying.
just saying.
Yea seafoam is good stuff, BEFORE you change ur oil right after only.
1/3 tank, 1/3 oil, rest in a vacuum line. let site for 15 mins, start that ***** up and rev like crazy for 10 mins lol
I was just doing a little research, anyone ever read this article?
Never thought of contamination on returnless fuel systems or misfires while turning.
GM Techlink: Search Results
There's still fuel getting to the valves, just not as much as a regular fuel injection system. You have to think, how is that carbon getting on the backside of the intake valve if its completely sealed off to the combustion chamber right before ignition? I'm sure valve float is partially to blame, but regardless, there is a very small fraction of a second the intake valve is open during combustion.
used it like once a month
