Fuel Grade?
Old Apr 14, 2005 | 01:21 PM
NiteViper's Avatar
Fuel Grade?
what grade fuel does the cobalt require?
2.2L (regular, mid, or premium)?
2.0 (regular, mid, or premiu,)?
i have been looking around but can never find the type/grade of gas that goes in.
Old Apr 14, 2005 | 02:06 PM
zinner's Avatar
Moderator Alumni
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/what-octane-gas-you-guys-putting-your-ss-sc-1921/
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/question-re-fuel-1304/
Old Apr 14, 2005 | 05:25 PM
hokman's Avatar
That's the problem with most cars, they set the chip to allow use of the impossibly low grade of fuel (like 87)? Hampers performance even if you put in proper fuel, like at least 95.
Old Apr 14, 2005 | 05:33 PM
zinner's Avatar
Moderator Alumni
How does CA (canada) rate their octane R+M/2 ?
The highest we can get around here is 94. The US is strictly R+M/2 I have heard of other countries using different systems that producde results that are not on the same scale as R+M/2.
Old Apr 14, 2005 | 06:55 PM
NightRydinSS's Avatar
So if the highest grade isn't available to us Canadians, will there be much diff. in lost performance between the lower grades??
Old Apr 14, 2005 | 07:42 PM
c0baltss2005sunburst's Avatar
Premium is recommended for the SS, otherwise you will noticably lose power in the engine. I would assume just unleaded for other models.
Old Apr 14, 2005 | 08:18 PM
mcz34man's Avatar
the impurities in the lower grades cause build up in the engine trust me i know, i learned with my aurora
Old Apr 15, 2005 | 07:22 AM
Funky Cricket's Avatar
putting in anything higher than 87 in a standard US made engine that is in good running condition is just a waste of money (for the most part), you gain no performace and if you don't have good spark plugs/ignition system can actually dmg your engine.
Higher octance means LESS combustibility. yes it might be "cleaner burning" (depending on definition) but impurities are going to be the same between octanes for the most part and only vary by brand. some cars differ and will respond better with different fuels, yes, but higher performance cars need a higher octance to prevent detonation, or early ignition of the fuel do to increased cylinder pressure or higher temps in the engine, the higher octance feul combusts at a higher temperature, but also burns a bit quicker giving a higher performing engine more control over combustion timing and length. but for a regular car, this will not make a difference as it is not tuned to take advantage but is most likely made to the lowest common denominator with much broader tolerences.
Old Apr 15, 2005 | 09:14 AM
DanM's Avatar
The previous post is mostly correct. Octane is a detonation-retardant. Gasoline with a higher octane rating can be heated and compressed more before it ignites on its own versus gas with a lower octane rating.
In our superchaged engine, much higher cylinder pressures and temperatures are achieved as a result of the supercharger, so you need gasoline with a higher octane rating in order to prevent the charge from detonating.
You can use a lower grade, however the engine controller will sense the lower grade gasoline, and will retard the ignition spark to prevent damage. This, essentially, is igniting the charge before cylinder pressures reach so high a level that the charge detonates on its own. Because cylinder pressures are lower, performance is hurt.
Canada uses R+M/2 as well. There generally is not much difference in octane content in a 91 from Canada vs. 91 from the US.
Use 91 or higher, and you'll be fine. If you have to put a tank of 87 in, it won't hurt anything long term, but you won't get optimal performance on that tank.
There is NO use in putting anything over 87 in a 2.2L Cobalt or any other car not requiring it. People sometimes think it's "better" gas since it's more expensive. It's just throwing your money away.
Old Apr 15, 2005 | 11:47 AM
skyhunter1's Avatar
What about the oil
Hey guys i'm trying to get my friend to bring me back some oil from Germany because they don't sell american here in Italy. I don't have my car yet so my question is, if the 2.2 uses 5W 30? And I saw on another thread about using mobil1. Is that also a recommendation for the 2.2?
Old Apr 15, 2005 | 12:00 PM
redrocket's Avatar
oil
Mobile 1 is required for the SS due to the Supercharger gearing and heat.
Old Apr 15, 2005 | 01:39 PM
Vooduguru's Avatar
Amsoil is a better product, better filter, and yes a bit more, but not by much. Amsoil's been around forever.
Old Apr 15, 2005 | 08:15 PM
plyboy-illest's Avatar
premiu for the 2.0 any car with a supercharger or a turbo should use premiu just because it make the engine knock... and ****..
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
