G85 vs. Non-G85
Old Oct 20, 2007 | 05:23 PM
  #51
an0malous's Avatar
oh yes thats another good point.
winter driving the LSD will most definately help.
thats one time i do miss it.
Old Oct 20, 2007 | 05:48 PM
  #52
Elsven's Avatar
Yes in the rain too :P. The off road... well I don’t know lol, you would have to have someone shoot me if I took my baby off road :P. I even hate gravel roads the couple times I have had to drive them.
Old Oct 20, 2007 | 05:50 PM
  #53
an0malous's Avatar
i have 100m of gravel back ally to my garage.
it kills me, especially with a black car.
Old Oct 20, 2007 | 06:01 PM
  #54
h0l0caust's Avatar
i took the LSD because of the recaros but the main reason why i took it was becasue i drive my balt in the WINTER! and thats where the LSD is useful, you get more control accelerating on slush and snow.....trust me.
Old Oct 20, 2007 | 06:04 PM
  #55
an0malous's Avatar
yup i can believe that.
but with a set of steelies and good quality winter rubber, i find even alberta winters not difficult to work with.
Old Oct 20, 2007 | 06:50 PM
  #56
AaronSS06's Avatar
How do you know if your cobalt has LSD?
Old Oct 20, 2007 | 06:57 PM
  #57
an0malous's Avatar
next time your driving, take a sharp corner (turning left at a stoplight works great)
and really get on the throttle.
if it feels like it doesnt seem to be pulling hard, and your left tire wants to spin, you dont have an LSD.
Also if you have Recaro racing seats you have LSD.
or you could check your original dealer sticker if you still have it.
Old Oct 20, 2007 | 07:03 PM
  #58
CobaltDude06's Avatar
come on down to memphis man ill meet up with ya at the track and we can see if that thing works
Old Oct 20, 2007 | 08:01 PM
  #59
BlueSS-supercharged's Avatar
your not always going to be on the throttle tho, so like they said it helps in the snow and crap and just low speed driving compared to a normal SS. wisconsin winters sucked *****. and you cant always base things off a track, tracks are prepped for grip, the streets are the streets. i just feel you really have to say the LSD ones are or should be faster
Old Oct 20, 2007 | 11:30 PM
  #60
AaronSS06's Avatar
what does the lsd stand for?
Old Oct 21, 2007 | 01:02 AM
  #61
Elsven's Avatar
Limited Slip Differential, it slows a wheel down until it can get traction so its actually moving your vehicle rather then just spinning there doing nothing.
Old Oct 21, 2007 | 04:47 AM
  #62
AaronSS06's Avatar
well ill have to check what the dealer sticker stays once it comes back from the shop. i have the recaro seats. it has the 4.10 gear ratio!? i dont know
Old Oct 21, 2007 | 06:39 AM
  #63
LopsidedJester's Avatar
Originally Posted by INFE
how much did it run you to get lsd installed?? i agree that it does nothing for you in a stright line but every time i come out of a turn hard the one legged spin starts!!! Its so anoying!!!!
Well, we bought the whole G85 trans, but i'm sure it would be a lot more $ to get the LSD actually installed inside the trans. Otherwise it was just a simple transmission swap. And that one legged spin around corners was rediculous beforehand and it happened even at low speeds. Now if i'm spinning tire around corners its at high turning speeds and its usually both tires.
Old Oct 21, 2007 | 01:08 PM
  #64
Elsven's Avatar
What year is oyur car if its the 06 or before i think lsdomes with the recardo seats. Also if you call your dealer give them yor vin they should be able to tell you.
Old Oct 22, 2007 | 01:39 PM
  #65
PolishPauL's Avatar
Does the lsd put less hp down to the wheels? I read somewhere that its 12% loss with jus fwd and 15% with lsd too.
Old Oct 22, 2007 | 01:48 PM
  #66
thedubsack85's Avatar
lighter wheel's will help.. no 18's is what im gettin at.. and boost limit first under 4k... you will cut some seriously good 60's and quarter's.. LSD help's out of the hole. AND out of the corner..
Old Oct 22, 2007 | 05:20 PM
  #67
an0malous's Avatar
prove it
Old Oct 22, 2007 | 05:26 PM
  #68
prove it
i beat a 2.85 pulley hptuned on a solid trans mount 05 RL while he was catless. (dig, even worse from a roll)
the 07 i had was stage 2 with bolt on's.
id go to ventura stock tune with bolt on's and beat SS/SC's with more bolt on's on a stock tune or the stage 2 SS/SC that was otherwise stock.
less weight=better power to weigh ratio...
Old Oct 22, 2007 | 05:31 PM
  #69
an0malous's Avatar
not the wheels :P
we all know the 18s suck.
i mean the comment that an LSD helps from a dig
Old Oct 22, 2007 | 06:22 PM
  #70
not the wheels :P
the 2.85 was a non lsd RL... one tire fire..
Old Oct 22, 2007 | 07:36 PM
  #71
hatrickstu's Avatar
ok so what kinda times you running hoss. im sure my minimal bolt on stage 2 car is no challenge as far as track times go. especially because im still on the 18's and with 320 tread wear tires...
Old Oct 22, 2007 | 07:54 PM
  #72
HickOverLOrd's Avatar
My opionion so far with the LSD is that its awesome of course, lol. Havent takin it to the track yet to see if it does do anything but on the street, it helps a little bit taking off. Just my opinion since ive owned a non g85. Corners are the **** now though, lol.
Old Oct 22, 2007 | 09:06 PM
  #73
AaronSS06's Avatar
lsd
i have a 2006. the dealer sticker doesnt have the 795$ option. so idk
Old Oct 22, 2007 | 10:16 PM
  #74
05redline's Avatar
No it doesn't. Racing another car or two doesn't really prove it either. 1st will spin and hop all over the damn place too with the LSD with a hard launch, I know I've driven both.
That's where the LSD really stands out.
Old Oct 23, 2007 | 04:23 PM
  #75
ive had the LSD pull me straight after incorrectly taking a high speed canyon turn at night. over 40 MPH. it was nuts.. i believe the trans is stronger with the LSD cause of the carrier and i believe a stronger roll pin. and trust me the 07 stage 2 tune boosts 11 to 12 at 2k so i know about spinnin a LSD RL.. its a FWD car its gonna spin regaurdless.. i got to drive a custome tuned RL with no lsd and it was a dream to launch. boost scaled back under 4k.
