Gear Calculations--Helpful site
Old Aug 15, 2006 | 03:51 PM
Zivnuska's Avatar
Thumbs up Gear Calculations--Helpful site
A helpful site to calculate the top speed in a specific gear(s):
http://www.turnzero.com/technical_re...ear_calculator
___________________________________________
Click on Transmissions on the following page to get the Cobalt data:
http://www.chevrolet.com/cobalt/specifications/
For my SS/SC Final drive ratio = 3.94
Gears 1-5...... 4.05, 2.02, 1.35, 0.98, 0.69
Tire 215/45/18
Max RPM Stock 6500; Stage II 7000rpm
Skip the tire deformation/flex adjustment.
Enjoy!
Old Aug 15, 2006 | 04:08 PM
Tomtwtwtw's Avatar
Good find! Those ratios are incorrect, though, despite them being listed on the USA Chevy site. (when will they fix it, anyway?)
The correct numbers are:
1st - 3.38
2nd - 1.76
3rd - 1.18
4th - .89
5th - .70
Reverse - 3.17
Final drive is 4.05
Also, redline is technically 6450 stock, although that will have a minimal effect on the numbers.
On running those numbers, though, the results are interesting. The website is off by about 3% on the fast end. I wonder where the discrepancy comes from?
Old Aug 15, 2006 | 04:33 PM
Zivnuska's Avatar
Thanks for the corrected ratios. The tire deformation/flex correction will adjust the numbers about the 3 % you are looking for.
Stage II 7000 rpm max
1st gear: Total gearing in first gear:
Maximum speed in first gear: 13.689
37.7 mph
2nd gear: Total gearing in second gear:
Maximum speed in second gear: 7.128
72.4 mph
3rd gear: Total gearing in third gear:
Maximum speed in third gear: 4.779
108 mph
4th gear: Total gearing in fourth gear:
Maximum speed in fourth gear: 3.6045
143.2 mph
5th gear: Total gearing in fifth gear:
Maximum speed in fifth gear: 2.835
182.1 mph
For 6450 rpm
34.7 mph
66.7 mph
99.5 mph
132 mph
167.8 mph
Do those results look correct to you?
Old Aug 15, 2006 | 05:29 PM
Tomtwtwtw's Avatar
Those numbers are dead on. Thanks for the tip.
So I guess that adjustment figures in the weight of the car pressing down on the tires, effectively reducing the diameter ever-so-slightly?
Old Aug 16, 2006 | 07:43 AM
Zivnuska's Avatar
Yep.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Delta coupe
Sep 30, 2015 08:11 AM
MrInsanityWolf
Sep 29, 2015 04:54 PM
