GM stage 1 LNF upgrade need help
Recently purchased the stage one upgrade. Long story I bought the kit second hand for really cheap(which is still brand new and in the package) and dont have the installation instructions with authorization code on it. Contacted GM and no help, contacted the vendor and they sent a receipt with a 8 number code that comes up invalid. My question is who do I contact to get the calibration code or a new one or am I s**t out of luck?
Basically the calibration code is a one time use thing that gets associated with your VIN in GM's system for warranty purposes. Since you are likely not in warranty anymore, and if you actually do have the stage 1 sensors for the LNF, you can just get someone to HP tune you. If you want, you could even use HP tuners to flash the stage 1 tune on for you since people have copies of the GM tune.
That's a good question. There are tons of people out there with tuning experience. You'll need someone local. Since you are from El Paso, I would suggest posting in the El Paso thread that you are looking for some help from someone local with HP tuners. That would be your easiest route.
Here you go: https://www.cobaltss.net/forums/sout.../index245.html
Real talk. Send ur pcm to zzp for a hpt tune better then gms1. Or buy a pcm and sent it to them if u don't want ur car MIA for a week or so. Then u can get hpt hardware later and get sombody to write u a custom tune. U get enough power without having to drop a lot of cash. U might just like the canned tune from zzp.
