Goodyear Eagle F1s
Goodyear Eagle F1s
Ok i know the stock tires are 215/45/18... Im ordering these goodyears but what size is best. I want 225/?/18. Someone help me fill in the middle numer. Should i get 45 or 40. What the defference. ANy problems with 45?
I have the 225/40/18's and they are smaller than stock.
40's = 2.117% too fast
45's = 1.398% too slow
I went with the 40's to solve the rubbing issue i had with the intake and sportlines. Honestly the best fit would be 235/40/18 = 0.825% too fast but than there might be rubbing issues on stock rim.
Last thing is I dont think these tires come in 225/45/18 i havent seen them but its possible.
How bout Continental's? The Continental ContiExtremeContact (Ultra High Performance All-Season) come factory on many cars here in Germany and the shop I took the balt to for winter shoes said these would last for a good 40 to 50K if maintained properly.
Originally Posted by 05OrangeSS
pretty sure you can get 225/45/18 I personally have the 235/40/18's on my car.....they work great with no issues at all.
i have checked a few places show my where i can get these tires in that size cuz i wanna put them on the back.
Originally Posted by hatrickstu
only on the back? mismatching tires is not a good decision
Originally Posted by akJBody
gotta love BFG KDW-2s....mmmmmmmhhhhmmmmmmm....
Id go with 225/45/18s. Little bit taller sidewall than stock.
I have the 235/40/18 eagle F1, i love them, probably will buy another set when these wear out!! NO rubbing issues at all!!! the second number in a tire size is called and aspect ratio. It tells you the height of the sidewall in relation to the tread width. I.E. a 250/50/X tire will have a 125 mm sidewall the aspect ratio is %50. so a 300/50/X tire will have a 150 mm sidewall. So even though the tires have the same aspect ratio, 50, the wider tire will have a taller sidewall. So with the sizes you are considering 215, 225, 235 you are only looking at a difference of a few mm in sidewall height. my speedo is not off any either!!
yea definetly give them a try. i thikn they fit the stock wheesl better than the stock tires. not to mention the look a hella lot better. they fill the rear out some and meet up perfect with the edge of the fender well
Originally Posted by CobaltSS422
05orangeSS (chris) has the falken azenis i forget which ones though
I have the F1's right now.....will probably get the azenis rt615's after this though.....
ahhh.. why did i think u had the azenis.. hmm.. oh well... this sucks but i need to get new tires as well and i'm afraid because i don't want my axels to break when we go to the track chris so i'm looking into replacing the stockers
