Got problem! NEED HELP
Old Apr 23, 2013 | 03:33 PM
scotia_ss's Avatar
need to figure out how to get into my trunk as i have recently taken it out fo storage and when i put it in i left the trunk slightly open but when the moved it to get other cars out the closed it not knowing that the cars battery was in the back, when i bought the car used it only came with a ignition key, so my key doesnt open the doors or trunk so thats out. The guys afraid he doesnt know what cables are disconnected from the battery so he doesnt want to jump it from the power post and short or fire something. So what5 are my optins here thinking bout drilling out the lock as i cant use it anyways but dont know how its done. any other ideas will be consider or adives. Damn cobalts and having everything in the trunk, even the seat release
Old Apr 23, 2013 | 03:41 PM
Sox-Fan's Avatar
Got Brakes?
A good locksmith can pick it for you.
Old Apr 23, 2013 | 04:07 PM
PsychoGenius's Avatar
Am I thinking about this wrong, or what... but my key does the ignition and doors/lock/trunk. I didnt know there are separate keys for each?
Old Apr 23, 2013 | 04:10 PM
Sox-Fan's Avatar
Got Brakes?
If the ignition has been changed that wouldn't be true.
Old Apr 23, 2013 | 04:31 PM
jrmotosports 88's Avatar
i can reach the seat release through the split in the seats.....
Old Apr 23, 2013 | 05:08 PM
Balt53's Avatar
I have done the same thing. If your at you house or near electricity then hook a battery charger up and press the but next to the steering wheel and open it
Old Apr 23, 2013 | 05:17 PM
silver187666's Avatar
go to a dealer with the vin and proof of vin like insurance or title and they can cut you a key
Old Apr 23, 2013 | 09:44 PM
joshcsepegi's Avatar
Withount the battery connected jump point won't work. Battery closes the loop.
Find the power cable.
Old Apr 23, 2013 | 11:39 PM
JshLnsctt's Avatar
^I would think if you try hard enough or find someone you can reach through, by far the simplest solution
Old Apr 23, 2013 | 11:56 PM
Whitnith's Avatar
A) The actual trunk pop button in the car is the simple solution, if you are inside the car.
Which leads to:
2) He can't get in the car, period. A good locksmith should be able to get you in the car, and then just pop the trunk with the release button.
Old Apr 24, 2013 | 12:05 AM
JshLnsctt's Avatar
Which leads to:
I would assume he has access to the inside of the car, because he mentioned that he can get at the power post. The power post is under the hood, and the hood unlock is inside the car.
Old Apr 24, 2013 | 04:55 AM
C_A_D88's Avatar
Gotta love ppl giving out the wrong info
Just hook up some jumper cables to the red post under the hood by the fusebox and a ground
Go inside the car and pop the trunk with the lil button
Old Apr 24, 2013 | 08:10 AM
Whitnith's Avatar
I'm pretty sure he can't get in the car, so jumping it with the power post is still out. He said his key won't open the doors or trunk. If he could get into the car, he wouldn't be asking about drilling out the lock on the trunk.
Old Apr 24, 2013 | 12:02 PM
JshLnsctt's Avatar
"The guys afraid he doesnt know what cables are disconnected from the battery so he doesnt want to jump it from the power post and short or fire something."
If he can get to the post he can get in the car, he just doesn't want to use the post. He is talking about drilling out the trunk lock
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
