Head Light
Head Light
i have an 07 balt and its all blacked out the windows and the rims any ideas on what i can do to the head lights i have seen alot of stuff dine to them but i dont know how to do it some help would be great
thanks
thanks
Original Hayden Fanatic
https://www.cobaltss.net/forums/how-guide-43/how-paint-your-headlights-lots-pics-56k-mabye-16874/
i suggest instead of the hair dryer you bake them in the over at about 200* for 20mins it will make it 100x easier to pull apart
Thank goodness I found a used headlight on e-bay for $19... should have this fixed by the end of the week
one thread not enough?
https://www.cobaltss.net/forums/showthread.php?t=67361
now pick which ever one you want to delete, them go to:
thread tools at the top, then click delete, and its done...
60 bucks unless you're stupid like me and try to use goof-off on the headlight covers to take off some sealent that gooped onto it... Word to the wise, Goof-off has no effect on the OUTSIDE of the covers, but will turn the inside of the lens into a milky white haze
dont bother taking the goop off, leave it there dont scrap any sealent off the lens or the housing... that way when your ready to put them back together you just heat them in the oven (~200* for 15min.) to get the sealant all goopie, then run a quick bead for extra seal & stick em back together... why waste time scraping it off when it can be reused??
how about when your pulling them apart and the "goop" is hot/warm and it strings out and swings into the inside and sitcks onto the inside of the lense, near the middle... in that case you might want to get it off, otherwise you have a line of "goop" going through the front of the lense.
personaly i love the painted look and i am also going to go for a brighter bulb to like a bmw i hate after market halo's i think they look boarder line retarded but very one has there own out look on things. for those who said painted could you give me a list of instructions of how to and what kind of bright ass bulbs should i get and where can i find them
Sep 28, 2015 12:51 PM
