Headlight Reflector
Old Nov 3, 2008 | 03:17 PM
mcphatty's Avatar
Headlight Reflector
So, my headlight reflector popped out of its spot the other day, now it's just bouncing around inside my headlight housing. I have a feeling I already know the answer to this, but does anyone know of a way I can pop it back in without separating the lens from the housing?
Old Nov 3, 2008 | 03:24 PM
Omega_5's Avatar
1) Take out headlight
2) Take out bulb, etc
3) Establish which pin it came off of (there are 3 possible pins... and it's probably the adjustment one)
4) Screw in adjustment screw, to set pin in further
5) Take hair dryer to inside to soften up the pin 'sockets'
6) Reach inside with finger (or other tool), pull like hell, and hope it pops back onto the pin.
I had the same thing happen once... and the above seemed to work fairly well.
Old Nov 3, 2008 | 03:29 PM
mcphatty's Avatar
im sorry, i should have said this better. it wasnt the headlight reflector, but the orange reflector on the side of the headlight, not the turn signal, but the small square one.
Old Nov 3, 2008 | 03:31 PM
BLAZIN07SS's Avatar
I'm too JDM for you
same thing happened to mine twice. the first time i fixed it without opening the headlight and it fell out 2 days later. lol. then i opened it up and krazy glued that bitch. btw you want to fix this quickly, my reflector warped a little from so much heat in front of the headlight
Omega_5's Avatar
Oh... in that case... your fucked.
Gotta pull the front off.
Old Nov 3, 2008 | 05:32 PM
mcphatty's Avatar
thats what i figured, but if i didnt have to i would have preferred to go that route. oh well, thanks for the input guys.
Pasierbek
Dec 10, 2015 07:22 PM
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
