Headlight Silicones?!!!!
Old Nov 22, 2012 | 02:03 AM
MyBalt10's Avatar
Exclamation Headlight Silicones?!!!!
Not sure if this is the right spot to post this. 3 times now I've used RTV silicone to reseal my headlights. They fog up every time. What in the hell can I use to keep them from fogging up. I'm very pissed with cobalt headlights at this point. What can I use that's easy to find and works good? Please help me!!
Old Nov 22, 2012 | 02:32 AM
cluelessk's Avatar
Get any moisture out and then use windshield urethane maybe? Don't know how it would bond to plastic though.
Old Nov 22, 2012 | 04:51 AM
C_A_D88's Avatar
U don't want the headlights 100% sealed or u
Will always have fogging with any temp change
Old Nov 22, 2012 | 08:35 AM
TommySS's Avatar
I believe the headlights are vented, and perhaps the vents are blocked
Old Nov 22, 2012 | 08:42 AM
Xmetalhead2003X's Avatar
I've been looking to do a retrofit myself and have seen this glue recommended elsewhere:
OCI Butyl Rubber Glue - Accessories from The Retrofit Source Inc
Old Nov 22, 2012 | 09:15 AM
C_A_D88's Avatar
The headlights are infact vented and not sealed 100% from factory anyways as in the back where the bulbs goes in there should b a hole in the rubber gasket
Old Nov 22, 2012 | 10:27 AM
CannonBalt's Avatar
You want to use this.
Old Nov 22, 2012 | 10:44 AM
dakotaspeir's Avatar
#cobalthoes
Yup butyl base is amazing that's the only thing I ever use
Old Nov 22, 2012 | 12:16 PM
Whitnith's Avatar
As others have said, if you are completely sealed, you will have fogging problems.
Easiest way to fix it is just drill a tiny hole on the bottom side of the light.
Old Nov 22, 2012 | 12:18 PM
Bass_Waves's Avatar
i used RTV silicone rubber. sealed up nice. the headlight always vented thru the back though where you secure the bulb at.
Old Nov 22, 2012 | 01:54 PM
Omiotek's Avatar
they need to be vented HOWEVER even factory headlights fog up and haze. my are a perfect example. the butyl stuff is the best to use. restrofit source sells it cheap .
Old Nov 22, 2012 | 02:51 PM
victoryredturbalt's Avatar
i usually use 'GOOP Automotive' good stuff.
Old Nov 22, 2012 | 03:10 PM
C_A_D88's Avatar
I used the original butyl just heat up press back together, then a too layer of automotive goop
Flows out nicely
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
dennis69
Sep 17, 2015 12:52 PM
