Heat Exchanger Question
Old Aug 22, 2007 | 02:40 PM
2fastforyou's Avatar
Just wanting to know if i can run the CA heat exchange on my stock setup or if anyone has it i would like to know how it is. i plan on getting one and i heard they are great with the GMS2 so lemme know
Old Aug 22, 2007 | 05:33 PM
all4glh's Avatar
Shoot, i already have one and i can't find someone that can tell me if the stock hose is 3/4" OD with 5/8" ID or if it's 3/4" ID. That's the only thing holding me back from installing it.
Old Aug 22, 2007 | 05:39 PM
BlilBT's Avatar
Yes you can run a 2nd H/E on the stock system, Look into getting the dual pass endplate to recieve the full benefit of the 2nd H/E
The Hose needed is 3/4 Heater hose, Try not to use rigid because it has to bend around the Radiator & Mounting subframe!
Old Aug 22, 2007 | 05:57 PM
so i can just use the H/E system. and do i really need to get the dual pass
thats a dumb question but it works good on stock? i know s2 it helps alot
Last edited by 2fastforyou; Aug 22, 2007 at 05:57 PM. Reason: Automerged Doublepost
Old Aug 22, 2007 | 07:34 PM
all4glh's Avatar
I understand that it's 3/4", but before I start tearing stuff apart i just want to know if it's 3/4 Inner Diameter or Outer Diameter.
Old Aug 22, 2007 | 08:59 PM
BlilBT's Avatar
The Hose I bought which I said was 3/4 Heater Hose which is the same standard 3/4 inch they have been using for a Long time & it Measures alittle over 5/8 Inside Diameter!
But you dont have to ask just go outside & Measure the outside Diameter of the 1 on you car Right Now & you would have your answer!
Old Aug 22, 2007 | 09:04 PM
all4glh's Avatar
Thanks, cause when i went to the local parts store they handed me 3/4ID hose. I thought I got the wrong one but you confirmed it. Thank you.
Old Aug 22, 2007 | 09:10 PM
Freakenhye's Avatar
I would wait for lightening force to come out with the cobalt dual pass inter cooler which should be about 3 more weeks.
Old Aug 22, 2007 | 09:11 PM
Shortbus's Avatar
The CA h/e comes with stainless steel braided lines....
Old Aug 22, 2007 | 09:42 PM
all4glh's Avatar
I bought mine in a GB on RLF almost a year ago while I was in Afghanistan, it did not come with the AN lines.
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
n20saturn
Sep 30, 2015 12:26 AM
Extremespeed
Sep 29, 2015 04:34 AM
jmelton327
Sep 26, 2015 10:04 PM
