Heating up engine in cold weather
Old Dec 7, 2006 | 03:22 PM
SS_Ry's Avatar
i drive as soon as I can see (as long as i can see blurry objects im fine haha)....although it sucks that by the time im starting to get heat through the vents im already where i wanna go....
Witt's Avatar
Originally Posted by HackAbuse
acutally it did make quite a bit of difference, the engine heats up substaintially faster.
There are several plastic items directly above the manifold, notably an acrylic tube that houses my engine bay lighting, which is DIRECTLY above the manifold, I haven't seen any signs of damage to anything yet, and the shield has been gone for about a month now
If anything, heat would be lost as that shield also acts as an insulator for the primary o2 sensor. To say it heats up engine coolant temperature by releasing heat from the maniold to the rear of the engine bay and out the hood lacks logic imo.
Old Dec 7, 2006 | 03:25 PM
HackAbuse's Avatar
I'm not trying to argue physics with you, im just saying, statistically, since then the engine coolant meter rises at a faster rate after startup, and the car is already producing interior heat after 1 mile of use or less
Old Dec 7, 2006 | 03:26 PM
HackAbuse's Avatar
Originally Posted by joeworkstoohard
i'm not saying that you will have issues, just that you should watch for them, is all.
Oh, I will be checking under that hood very frequently, its the only thing that gets me off besides my girl
Old Dec 7, 2006 | 03:58 PM
FinalBreath's Avatar
I usually give it 5 mintues or so. especially with this single digit weather
Old Dec 7, 2006 | 04:15 PM
p7x's Avatar
p7x
its not to cold out yet so once it hit 80 im off but once it starts getting below freezing than i get it till past 100
Old Dec 7, 2006 | 07:37 PM
YSUsteven's Avatar
Once its above 50 F I drive and try to keep it under 2 grand, emphesis on try. Once it gets to 160 F drive normally, usually under 3 grand.
06MetallicBalt
Jul 20, 2025 08:47 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
jmelton327
Sep 26, 2015 10:04 PM
roth
Sep 26, 2015 12:16 PM
