help !!!!!
help !!!!!
I was driving in manhattan yesterday I went to take off in first gear my car stalled and wouldn't turn back on. It would about to start then shake then die again. I was already an hour and a half into my trip keep in mind my low coolant light has been on forever like 6. Months and I have ignored it could that of been it ?? What would cause this. Also I have been putting regular gas in it for a while
Low coolant was on and you didn't fix it? Rings are probably shot at bare minimum. Gaskets are all shot probably from over heating. Not to mention the high knock from running regular. Your engine is probably toast.
Start by seeing if you can pull the plugs. I bet you'll get to one cylinder and the spark will break lose but will not come out without excessice force.
I don't understand why you've been putting regular in the car...
In all actuality, it could be something little like the crank sensor or could be serious. You won't know until you take it somewhere to get looked at as it's obvious you have no clue what's going on. I recommend nothing in Jackson, that town is.... Well nevermind.
Get the car towed to Tune Time in Toms River.
try and reset ur codes first... that might fix it. and if it does, fukin go put some coolant in!!!
and u really should run higher octane unless u NEVER go WOT
And yes its most likely internals.
umm what happens when u try to start your car? Do it start in reduced power mode (sounds like a serious ******* cam), if so try and hit the gas do you get a response from the vehicle, or does it just die out???
Guys gtfo if you aint gunna help the man, seriously he knows he fucked up lay off
If you take the time to read the manual, it says that 91 is recommended but not required for both the 2.4 and 2.0. 87 is fine in the 2.2. You can run 87 in the 2.0 and 2.4 as well, but the computer might pull some timing due to detonation.
