help !!!!!
Old Oct 27, 2008 | 07:18 AM
dylan1221's Avatar
help !!!!!
I was driving in manhattan yesterday I went to take off in first gear my car stalled and wouldn't turn back on. It would about to start then shake then die again. I was already an hour and a half into my trip keep in mind my low coolant light has been on forever like 6. Months and I have ignored it could that of been it ?? What would cause this. Also I have been putting regular gas in it for a while
Old Oct 27, 2008 | 07:28 AM
tREBs's Avatar
well first thing... your an IDIOT for putting regular in it... stop being cheap.
second, why would you ignore the low COOLANT light? not like thats very important...
Old Oct 27, 2008 | 07:34 AM
slowswap's Avatar
Low coolant was on and you didn't fix it? Rings are probably shot at bare minimum. Gaskets are all shot probably from over heating. Not to mention the high knock from running regular. Your engine is probably toast.
Start by seeing if you can pull the plugs. I bet you'll get to one cylinder and the spark will break lose but will not come out without excessice force.
Old Oct 27, 2008 | 07:42 AM
Cobalt Mav's Avatar
Um wow. Have fun with the rebuild. Not smart.
Old Oct 27, 2008 | 07:43 AM
slowswap's Avatar
Just when you thought you've encountered the stupidest member on this site, another one will pop up with an even worse story.
Old Oct 27, 2008 | 08:14 AM
dylan1221's Avatar
thank you for stating the obvious I know it's stupid but I just wondering would that be the cause of stalling and not getting the car back on
Old Oct 27, 2008 | 08:19 AM
SSdan's Avatar
I don't understand why you've been putting regular in the car...
In all actuality, it could be something little like the crank sensor or could be serious. You won't know until you take it somewhere to get looked at as it's obvious you have no clue what's going on. I recommend nothing in Jackson, that town is.... Well nevermind.
Get the car towed to Tune Time in Toms River.
Old Oct 27, 2008 | 08:22 AM
originaladrian's Avatar
karma- u abuse ur car and this is what happens.
try and reset ur codes first... that might fix it. and if it does, fukin go put some coolant in!!!
and u really should run higher octane unless u NEVER go WOT
Old Oct 27, 2008 | 08:27 AM
slowswap's Avatar
Pull plugs and do a compression test, if the motor still wants to turn over.
Old Oct 27, 2008 | 08:30 AM
brickerenator's Avatar
fuses
Old Oct 27, 2008 | 08:43 AM
Erod's Avatar
Moderator Alumni
Take it to a dealer.
Period.
Scythe_Snake's Avatar
You answered your own question. You didn't keep the maintenance on your car and decided to put the lowest octane you could possibly put in your car....I'm sorry, I don't wish bad on other people...but you HONESTLY deserved it.
And yes its most likely internals.
Old Oct 27, 2008 | 08:50 AM
camarokiller's Avatar
Check your fuses
Old Oct 27, 2008 | 09:08 AM
04redline0124's Avatar
umm what happens when u try to start your car? Do it start in reduced power mode (sounds like a serious ******* cam), if so try and hit the gas do you get a response from the vehicle, or does it just die out???
Guys gtfo if you aint gunna help the man, seriously he knows he fucked up lay off
Old Oct 27, 2008 | 09:09 AM
iirc the car doesn't start
Old Oct 27, 2008 | 09:12 AM
but it says it shakes then dies....jsut wondering because I had a similar problem but my sensor for the TB came out so there was no throttle response
Old Oct 27, 2008 | 10:50 AM
SSdan's Avatar
I had that before too and it's the crank sensor. Did it three times and hasn't since.
Old Oct 27, 2008 | 11:29 AM
dylan1221's Avatar
well I finally got it started don't know what it was it's sitting now b4 I ddo my 2. Hour trip back ill just put so anti in it
Old Oct 28, 2008 | 01:58 PM
adamo41188's Avatar
isnt he supposed to put regular in it if he isnt S2? Assuming hes not S2 form his sig.
Old Oct 28, 2008 | 02:06 PM
ACESSbalt's Avatar
btw you can run regular as no where it the manual does it say it requires anything more dont know where the myth that you have to comes from...assuming your not S2 of course
Old Oct 28, 2008 | 02:09 PM
adamo41188's Avatar
exactly. And your not tuned for it so its a waste of money cause it doesnt help at all
Old Oct 28, 2008 | 02:53 PM
slowswap's Avatar
If you take the time to read the manual, it says that 91 is recommended but not required for both the 2.4 and 2.0. 87 is fine in the 2.2. You can run 87 in the 2.0 and 2.4 as well, but the computer might pull some timing due to detonation.
If you run 87, the motor will have to detonate before it retards timing for the 87. Is that really worth running the risk?
Old Oct 28, 2008 | 10:37 PM
ACESSbalt's Avatar
lol not sure i run at least 91 in MY car but i was just sayin you dont have to
Old Oct 31, 2008 | 03:04 PM
samijo0703's Avatar
huh thats odd my manual said 93 only
Old Nov 7, 2008 | 07:50 AM
origami78's Avatar
Sounds like a bad crank position sensor
