help, high coolant temp
before you ask, I have a 2006 SS/SC and my only mod is an intake.
with that out of the way, I was parked in my drive way when i noticed my coolant temp was 210 and I thought to myself that's high even my G5 would start cooling off before that. so I popped my hood and didn't notice anything out of the ordinary. so I then let it continue running to see if it'd kick the fans on shortly, it wandered up to 223°f before I said F this and shut it off and came inside to ask you guys for advice.
no my fans never kicked on.
my normal running temp is 180 when I'm driving around.
Posted from Cobaltss.net App for Android
for one if it's sitting still it will get hot with no air flow. two youre ic pump is prolly dead.
and I'm fairly sure my ic pump did take a crap too. I'm ordering a new one tonight or tomorrow to be safe
Originally Posted by Sox-Fan
Are you low on coolant?
wait until it cools to check or add
wait until it cools
wait until it cools
so you don't melt your face.
wait until it cools
wait until it cools
Thermostat opening when it should? Does it push liquid into the expansion tank when the thermostat opens? Or pull it in from the tank?
nope. checked all that on my lunch break today. I'm in the habbit of checking the important fluids thanks to the girlfriends car since it eats oil and very slowly leaks coolant somewhere. its a 02 Saturn sc2 with 220k on it so yeah. haha.
If no one's solution is helping, you might be thinking issue based off experiences with other cars, I've done it before
Burns oil because stuck rings. Hop on sixthsphere.com aand read the sea foam procedure I wrote.
anything under 227* and you're fine. the fans will go on High at 226/227* the car was sitting still, and right now with the cold weather the car wants to warm up,. it will create more heat for itself like that. Let it do it again and then go take it for a drive it should drop within 2 minutes if not quicker down to the 180-190 range.
Quote:
Leaks coolant from the end tank; most likely spot. Drivers side, just below the hose inlet. New radiator needed.
Yep, your temp is within the normal range. Especially sitting still. My ss/sc got well into the 220's every time I got food at a drive through.
Also, the IC pump has zero to do with coolant temp...check to make sure it's broken before you replace it.
Also, assuming you do have the right coolant / water mix in there, you aren't risking any kind of engine damage until you're over 260. So you have plenty of wiggle room.
well I'm the second owner and I'm 90% sure the previous owner didn't change the pump with the condition it was when it got traded in at my work. it has 89,000 on it now. it needs it.
I'm still getting used to the way this car behaves, I'm just not used to the coolant going past 210-215 since that's the highest my G5 would get in traffic and the drive threw
