HELP!!!!! None of my lights work!! (fuse?)
Old Apr 7, 2008 | 10:32 PM
Billig ss/sc's Avatar
So I was messing with my lights because one of my "halo rings" on my projectors blew out. So I'm working on it and I had everything prewired to make sure it worked and it did. So I turned off the lights and messed with things so the LEDs would look a little better. And I turned the lights on again and everything worked and as I'm walking back to turn them off, the headlights shifted (wasn't installed, just kinda sitting there) and I heard a slight "pop" sound (I think positive and negative wires touched) and now none of my exterior lights with the exception of my headlights and middle tail light work. What happened? Did I blow a fuse? If so, how do I fix it and which fuse is it?
Old Apr 7, 2008 | 10:35 PM
fballman1987's Avatar
pull the fuse box and check to see which one it is, replace it after checking..
How do I tell which one it is? And where do I get replacement fuses?
Old Apr 7, 2008 | 10:36 PM
Sunburst_SS's Avatar
yea, you shorted the wires together......check fuses in fuse block, see what's blown. Make sure and fix the wiring before you put a new fuse in, or you'll just pop it again
pull out the fuses, probably labeled for lights.....there will be a few, pull em out and see which ones look blown. The inside will probably be discoloed, and the metal will be seperated in it. You can get new fuses at pep-boys, autozone, etc.
Old Apr 7, 2008 | 10:37 PM
njg5gt's Avatar
running lights fuse sounds like to me
when fuses blow the insides seperate if there are 2 pieces of metal inside rather than 1 its blown.
Old Apr 7, 2008 | 10:44 PM
I pulled the DRL fuse and it sounds like what you just described. I'll grab a pic and post it in a sec to show you what I'm looking at...
Old Apr 7, 2008 | 10:47 PM
CinciSS07's Avatar
arent there unused fuses in our fuse boxes? they are labeles on the back of the fuse box i think. unless im thinking of another car haha
Old Apr 7, 2008 | 10:55 PM
Here's the fuse. The red arrow is pointing to the metal that I assume you guys are all talking about...
I think there is. I swear I've seen random fuses laying around somewhere. Unless I"m just thinking of my old car haha
Last edited by Billig ss/sc; Apr 7, 2008 at 10:55 PM. Reason: Automerged Doublepost
Old Apr 7, 2008 | 11:10 PM
blu3_v1p3r's Avatar
its not the DRL fuse its probably the parking lamp fuse... its under the hood as well. I had this problem.... none of gauges will light up either
yes there are they are on the right side of fuse box under the hood, and there are also 1 or in the box in the passenger side interior
Old Apr 8, 2008 | 12:20 AM
^^Fixed. You are correct, sir.
Lesson learned... gravity>me
Old Apr 8, 2008 | 06:08 AM
raikou's Avatar
I have some extra fuses in my garage! but that brings absolutely nothing to this discussion!
Old Apr 8, 2008 | 12:04 PM
^^Especially since it's fixed haha. Well I'm sure in the next few days I'll have some extra ones too
Old Apr 8, 2008 | 12:27 PM
blu3_v1p3r's Avatar
Your the second person i helped with this problem beside my self... as soon as i seen that your lights were out i knew what it was... lol
Old Apr 8, 2008 | 12:30 PM
^^Thanks man, I appreciate it. I was scared as hell when it first happened because I immediately thought worst case scenario and I thought I killed the car haha. But good to know in case something ever happens again.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
