Help from the Parts Department is here.
Old 05-01-2007 | 08:48 AM
  #676
fr33k's Avatar
Originally Posted by Jackalope
Fr33k, You are doing a wonderful job!!! I'm so glad you took over after I left GM to help everyone here. I wish I could still help you cause I remember its a PITA trying to answer evryones questons.
+ rep given my friend!
Thanks. I enjoy helping fellow balters How's your new job working out?
Originally Posted by Pyros777
Sorry if this one has been answered already, but I need the part number for this trim piece (05-06):
For the years of 05 and 06, the only way to get the trim is with switch too.
15274651 - SWITCH ASM-DRVR INFO DISPLAY *SATIN NICKEL
Dealer Price $18.78 List Price $32.94 Trade Price $24.71
Old 05-01-2007 | 10:25 AM
  #677
Red07SSNA's Avatar
fr33k,
Need part numbers for:
2.2 Vacuum hose from intake manifold to brake booster
2.4 Vacuum hose from intake manifold to brake booster
THANKS!
Old 05-01-2007 | 11:02 AM
  #678
fr33k's Avatar
Originally Posted by Cobalter LS
fr33k,
THANKS!
22723583 - HOSE ASM-P/B BOOS VAC 2.2
Dealer Price $11.32 List Price $22.64 Trade Price $15.85
10369041 - HOSE ASM-P/B BOOS VAC 2.4 1st design (05s all and 06-up used on vehicles with engine oil cooler)
Dealer Price $24.21 List Price $48.42 Trade Price $33.89
15855993 - HOSE ASM-P/B BOOS VAC 2.4 2nd design (06up used on vehicles without engine oil cooler)
Dealer Price $29.72 List Price $52.14 Trade Price $39.11
Old 05-01-2007 | 11:16 AM
  #679
Pyros777's Avatar
Thanks fr33k. I was actually hoping it was the whole assembly with both switches.
Old 05-01-2007 | 11:28 AM
  #680
fr33k's Avatar
No problem. If ya need anything else, just holla
Old 05-01-2007 | 11:56 AM
  #681
Red07SSNA's Avatar
Is there more than one 2.4 intake manifold? Since two 2.4 hoses are listed and the difference is whether or not it has the oil cooler I'm assuming that both hose's intake manifold connections are forward of, and just below, the throttle body (The 2.2's connection is on the rear of the intake manifold).
Thanks again for the assistance.
Old 05-01-2007 | 01:18 PM
  #682
fr33k's Avatar
It looks like there's only one intake manifold for the 2.4's. I guess the hose is rerouted to wrap around the cooler or something. GM is odd about that sort of thing. it might have a 60 degree bend on one hose and a 62 on the other so they make a whole different part number lol.
Old 05-02-2007 | 10:31 PM
  #683
Coop's Avatar
fr33k do you have any documentation or a part number for the newest stage 2 tune. I just had mine installed at a dealership and am only hitting 12.5psi. My rev limiter is at 6500 so something isnt right. I had it installed in January. Thanks
Old 05-02-2007 | 11:38 PM
  #684
jpEnterprize's Avatar
I got the Grandpa Ride . . .
2006 Chevy Cobalt LS Sedan
I'd like a price and contact information for replacement parts. I'd like to "blackout" my interior trim package . . . no chrome, silver, or wood-grain.
How much for a can of satin black spray paint?
OR
instrument trim package - black (I could only find red, yellow, & blue package)
door handles & cups - black (I have silver & brown)
door panel insets/armrest - black (I have brown plastic / brown cloth)
TIA
Old 05-02-2007 | 11:53 PM
  #685
Xavipheus's Avatar
holy beige batman
Old 05-03-2007 | 01:25 AM
  #686
thought's Avatar
Stage 1 and 2 are the same tune and should red line at 7K. If it doesn't, you don't have it.
Old 05-03-2007 | 01:51 AM
  #687
shifty's Avatar
What would be the #'s for the red door inserts for the SS/SC. Thank you.
Old 05-03-2007 | 09:12 AM
  #688
fr33k's Avatar
For you to only have the 6500 limiter, they forgot to do the tune.You'll have to go back and try and have them do the reflash correctly. Hopefully they give you the instructions because there is a code on it that they have to have to get the Stage 2 flash from GM. And there is no way just to buy that code.
You can't purchase the inserts alone from GM. They only come with the whole door trim panel.
25783814 - PANEL ASM-FRT S/D TR *RED RH
Dealer Price $120.39 List Price $211.20 Trade Price $158.40
25783815 - PANEL ASM-FRT S/D TR *RED LH
TIA
instrument trim package - black - The only black available is what you have on your pic.
inside door handle:
22722754 - BEZEL ASM-FRT S/D I/S HDL *EBONY RH
Dealer Price $10.70 List Price $18.77 Trade Price $14.08
22722755 - BEZEL ASM-FRT S/D I/S HDL *EBONY LH
Dealer Price $10.73 List Price $18.80 Trade Price $14.10
cups - black - The only colors for manual windows and locks is what you have.
door panel insets/armrest - black - Inserts are only serviced with the door panel itself.
Old 05-03-2007 | 10:52 AM
  #689
thought's Avatar
If you really need to get an authorization code again, you can always get a stage 1 kit. It has the same tune code for stage 1 and stage 2. Tell this to your dealership, cause that way they only have to write-off a stage 1 kit instead of a stage 2 kit. However, GM might maybe possibly be able to call this line and explain the goof-up and get a flash only (VCI Number):
TCSC 1-888-337-1010
Hope that helps
Old 05-03-2007 | 04:02 PM
  #690
Coop's Avatar
fr33k I did not get the instruction sheet back with my parts. So what are my options? I am not paying for a kit to get a code that is BS. You are or were a GM parts technician correct?
Old 05-03-2007 | 04:17 PM
  #691
fr33k's Avatar
Yup. I've been a parts tech for 12 years now If a dealership installed your Stage 2, then you should be able to go back to that same dealership and mention to them about your flash should of given you the 7K redline. They should be able to pull up your repair order and help you out. If they wont, then I would get a VIN from someones cobalt ss/sc that is using a GM flash and options and you can give that to the tech and they wont have to call GM or get a VCI number.
Once a car has the stage 2 installed and flashed, that info is transmitted to GM's servers. If you ever have troubles with your PCM, you can go anywhere in the US and get your PCM reflashed to the Stage 2.
I hope you didn't damage anything since you have been running your car this whole time with only factory programming. Your car dont know how to use the 42lbers and the extra boost.
Old 05-03-2007 | 07:26 PM
  #692
Coop's Avatar
Thanks fr33k. I have not seen a boost pressure over 12.5 on my car so that I why I started this. That is why I am asking for help.
Old 05-04-2007 | 12:20 AM
  #693
shifty's Avatar
Thanks for the info on the door panels. I was wondering if there is a part number for buying the SS/SC leather seats with red inserts. Thanks.
Old 05-04-2007 | 08:57 AM
  #694
fr33k's Avatar
The whole seats for the 2-toned interiors are not available. The only way is to get pieces of the seat (like seat covers, cushions, frames, etc). Is there a certain piece your needing or are ya wanting to just change your colors?
Old 05-05-2007 | 01:34 AM
  #695
shifty's Avatar
I am looking to replace the seat and the back rest of each front seat to red, so it looks like the original GM black SS seats with the red inserts. Does that make sense ?
Old 05-07-2007 | 09:35 AM
  #696
fr33k's Avatar
That's what I done with my Yellow Balt. I took off the factory cloth seat covers and replaced them with ebony w/yellow inserts from the SS/SC's. I also changed the cloth insert door panels with the yellow leather ones.
The rear seats are easy to do but the fronts can be a pain lol.
Old 05-08-2007 | 04:25 PM
  #697
tonio5555's Avatar
This thread has gotten massive and I tried searching but I can't find exactly what I need.
Could I have part numbers for the SS N/A rear bumper primed and also painted black so I can compare. Thanks Fr33k.
Old 05-08-2007 | 06:47 PM
  #698
blu3_v1p3r's Avatar
you can find these things on gmpartsdirect.com, and crateengiendepot.com... i think alot of people are just lazy and don't feel like looking... its seems to be alot quicker too
Old 05-09-2007 | 08:37 AM
  #699
fr33k's Avatar
Ya can't get one from GM already painted. They are only available primed.
12336077 - FASCIA ASM,RR BPR *PRIMED
Dealer Price $272.69 List Price $462.18 Trade Price $346.64
There's nothing wrong with asking. I dont mind helping fellow balters out. Plus, Crateenginedepot don't have the rear fascias listed on their site and gmpartsdirect doesn't have the online catalog to look up the part numbers for the cobalts.
Old 05-10-2007 | 03:17 AM
  #700
zzzzzzzz's Avatar
hi , im just curious. my car has had two steering gears put in, two steering columns, intm. shaft. steering rack asembly, 1 strut, 2 wheel bearings.... 1 shifter kit how much cash are we looking at
Quick Reply: Help from the Parts Department is here.
