Help programming key fobs using tech 2
Hi guys I ordered 2 eBay knockoff switchblade keyless entry keys and I had to take them to the dealer and get them cut . I had no problems with that it was free. I programmed the keys to my ignition and they started my car fine. Issue is when I try to do the keyless entry part not sure of the process or the body code that the tech 2 ask for. I will have access to the tech 2 again on monday. thanks in advance for any help
body code a is what ours is. then you will go to body systems, then remote control door lock receiver, then module setup, program key fobs. If you have all your remotes at that time just go through invalidate and relearn them all, if you don't then just go to next available slot so long as they aren't filled up with a learn status of "yes". instructions will be shown on the tech 2 at that point but
basically you hit learn then hold lock and unlock at the same time on each fob, going one at a time until the fob slot changes from no to yes, after that move to your next fob ulock and lock hold until you have learned them all. once you learned them all then hit done on tech 2. Check and make sure each lock and unlock on the fob works then at that point then you can shut off the tech 2
jmoney2001
Sep 23, 2014 06:31 PM
