Help Stop Wheel Hop
Old Apr 24, 2008 | 01:54 PM
soulja's Avatar
Help Stop Wheel Hop
I took my car to the track last friday and yesterday and got my first perfect launch 0.00 and wheel hop like a mother F*er and i want to know what is the best traction mod to do first to stop/eliminate wheel hop
Old Apr 24, 2008 | 01:57 PM
loco-performance's Avatar
search > you
ingalls, solid mounts
invisible's Avatar
Solid mounts or Ingnalls TD
Orange07ssinfl's Avatar
Well I would suggest either an Ingalls Torque Damper or solid motor mounts and tranny mounts.
Old Apr 24, 2008 | 01:59 PM
LamboW9's Avatar
tranny mounts and a ingalls T.D. we put my buddies on his last night..the stock trans mounts are disgusting...take a look an then you decide
dragonslayer27's Avatar
this thread sounds like a public service announcement like "help fight cancer". all of the above are correct. especially post #2.
Old Apr 24, 2008 | 02:00 PM
WSFrazier's Avatar
Complete BWoody Mounts from experience, don't bother with the TQ Bar.
Old Apr 24, 2008 | 02:01 PM
68nova200's Avatar
Drive Slower haha
Old Apr 24, 2008 | 02:04 PM
soulja's Avatar
lol ive never seen so many posts in so little time haha but i think everyone agreed thanks guys ill be buying them this week Solid mounts and Ingnalls TD both from cobalt addiction
Old Apr 24, 2008 | 02:05 PM
WSFrazier's Avatar
Don't run an upper solid mount and the Ingalls, lol.
All around solid mounts > Ingalls
WhiteSSBalt's Avatar
Not a Sebring
I have the Ingalls ETD + Prothane poly trans mount bushings. Its a good setup
Old Apr 24, 2008 | 02:09 PM
krazycobalt's Avatar
I have ingalls sitting in my room from cobalt addiction waiting to put it in. I heard they are great and i plan to get motor mounts later on
Old Apr 24, 2008 | 02:20 PM
LopsidedJester's Avatar
If you're experienced in modding cars and dedicated to power, i say fill your stock mounts with polyurethane. Cost me $25 for two tubes of polurethane and that was more than enough to fill all 4 mounts (yes there is an elusive 4th mount which makes all the difference in stiffening) and i filled two mounts on my sloshy mazda protege drivetrain.
TTR mounts and inserts, and zzperformance billet mounts are said to be great if you were to go that way, but you'll be spending $100's of dollars replacing your bushings and mounts and still nobody i know sells an aftermarket 4th mount. (4th mount is located on the top driver side where all the hopping happens)
Old Apr 24, 2008 | 02:27 PM
bigboybigtruck21's Avatar
mmm i guess i am the only one with traction bars...
Old Apr 24, 2008 | 02:33 PM
firemanfrank's Avatar
Who sells traction bars for the SS/SC?
Lakewood?
Old Apr 24, 2008 | 02:36 PM
Zach06CobaltSC's Avatar
soulja what did you run at the track, can you post the time slip? I told you in your last thread that you would need to eliminate the wheel hop remember? Blah if you want you can pm me and I will give you a run down of everything your going to need to achieve the goals that we both have haha.
To eliminate wheel hop, the most important thing you need is the prothane transmission mounts from turbotechracing.com then its either the ingalls tq or the solid motor mounts, its basically just personal preference which ever you would rather install or buy basically. I think I am personally going to go with the prothane tranny mounts and the solid upper motor mounts.
Heres a link to what you need in my opinion.
Prothane manaul transmission mount.
http://www.turbotechracing.com/produ...idproduct=4937
Solid upper engine mount.
http://www.turbotechracing.com/produ...idproduct=4933
Old Apr 24, 2008 | 02:38 PM
Bwoody
Old Apr 24, 2008 | 02:40 PM
Bwoody
Thanks!
Please tell me a little more about them ...
(ease of installation, how did they work, where did you purchase them, etc.)
Old Apr 24, 2008 | 02:42 PM
I am also interested in knowing a little more about the bwoody traction bars. How much do they cost, where did you purchase them, ease of installation etc. Thanks mate.
Old Apr 24, 2008 | 02:47 PM
i got them from Bwoody these are the full race version and where 300 the economy is a lot cheaper..Race version you get the chromly ends and the guys at the shop said they kick ass and where easy to install havent driven the car yet because i am in iraq
Old Apr 24, 2008 | 02:52 PM
thedubsack85's Avatar
ding ding ding... for only 230 for a full set two.. when TTR's top mount is 180 by it's self and 50+ for insert's that retain the WEAK ass stamped factory mount.. bwoody FTW!!!!!
oh and incase your wondering the website is www.bwoodyperformance.com
and if you think you can break them i DARE you to try.. they make solid mount's for 900+WHP SRT4's and have NEVER had a mount break.. and there full race traction bar's are SICK.. i was able to to do 4k clutch drop's with NO hop.. but make sure there tight.. cause if one get's loose you WILL snap an axel.. like i have..
Old Apr 24, 2008 | 03:19 PM
soulja's Avatar
I ran a 14.387 with only injen air intake, on a perfect launch my time slip is at home ill see if i can post. Wat was also awkward i finished at 100.37 mph and my 6 runs before that i ran 93 93 93 97 96 and 96 so i mean a great run for me even though i got smoked by a volvo wagon with a license plate reading vovette and under the hood running a corvette engine twin turbo haha. i was still proud.
Old Apr 24, 2008 | 03:27 PM
qwikredline's Avatar
Canada
At the risk of offending everyone as I have said it before, I will say it again. UNtil you rotate the engine, up 10mm at the rear pitch mount down 10 mm at the front pitch mount, you will not have the axles running in line, output from transmission to hub center line (M35 LSJ.
The root cause of the axle hop, can be traced based on what I have found to that issue. Sure the mounts are too soft stock, and the FLCA bushings are too soft, but the poor axle is trying to rotate at a 17 degree angle horizontally and go up and down vertically in ride travel ...think about it. We have made mounts for the Cobalt they are used in every Grand Am cup Cobalt...for the street, I am sure it will work. and no i havent fitted them to my Redline yet, that's next months project. PM me ONLY if you are interested in buying (not cheap) Cobalt rotated mounts I may have a couple on the shelf...
Old Apr 24, 2008 | 03:49 PM
TurboTechRacing's Avatar
If anyone has questions on the Turbo Tech Racing Upper Solid Engine Mount please PM us
Old Apr 24, 2008 | 04:34 PM
Canada
