Help Stop Wheel Hop
Old Apr 24, 2008 | 04:59 PM
jvc06sc's Avatar
Im not trying to thread jack or anything but my friends has a spec v with solid mounts and he gets mad cabin vibration. Is that common to all cars or does it vary by model
Old Apr 24, 2008 | 05:03 PM
TurboTechRacing's Avatar
Vibrations are always increased some, however they are very minimal compared to other solid mounts.
Old Apr 24, 2008 | 07:29 PM
qwikredline's Avatar
reasonable questions. You get nothing for nothing. Make it stiff you risk NVH (noise vibration harshness) that GM do a good job eliminating...I use UHMW plastic material for motor mounts, it has good temperature performance range and relatively soft. Too soft the stuff will tear up, too hard (Delrin is harder) and you get more vibration. If I had a lot of time to spend I would try moving the mount to rotate the engine and keep the stock bushing; that could work, but its time and money and if I was guessing I would say trade NVH for "wheel hop gone" . THen the forum will be full of posts " my tires wear out in 10,000 miles....
Old Apr 25, 2008 | 08:04 PM
firemanfrank's Avatar
Originally Posted by thedubsack85
... but make sure there tight [traction bars].. cause if one get's loose you WILL snap an axel.. like i have..
^Me no likes the sound of that.
I guess it's back to the wheel hop ...
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
