HID's...
Old Jan 27, 2008 | 02:05 PM
bruiserinpink's Avatar
HID's...
Can someone tell me how to install HID's, i looked in the how to section and didn't see anything, i might have missed it and i searched it and it didn't come up with anything so if you know how could someone please PM me or just post a response to this please!! thanks guys!!!
-ash
Old Jan 27, 2008 | 02:09 PM
Omega_5's Avatar
Huh?
It's as simple as putting the bulb in, and hooking up 2 wires.
Old Jan 27, 2008 | 02:11 PM
StoryoftheYear's Avatar
yeahhhhhh what he said.....
Old Jan 27, 2008 | 02:12 PM
Omega_5's Avatar
I guess if you want the whole story behind hooking up HID's, check this link out.... lots of info there.
http://www.hidplanet.com/forums/viewtopic.php?t=6612
Old Jan 27, 2008 | 02:21 PM
TheCaptain's Avatar
Originally Posted by Omega_5
Huh?
Providing she got a plug and play setup. There are still a few splice and dice kits out there.
Old Jan 27, 2008 | 02:26 PM
i can't go to that website because i'm not a member and i don't see a button to sign up either...
Old Jan 27, 2008 | 02:28 PM
Omega_5's Avatar
Register... third button from the left, on the top bar.
It's a great site to browse around on...
Old Jan 27, 2008 | 02:29 PM
TheCaptain's Avatar
Are they 9007 HIDs? For stock headlights?
Or do you have some Projector headlights, using H1 HID bulbs?
Tung's Avatar
search harder
Old Jan 27, 2008 | 02:50 PM
hey i didn't ask for anyones attitude, if you have a problem with me tryin to find somethin out keep it to yourself
and they are 9007 HID's for stock headlights yes
my boyfriend is outside working on them igt now and he just wanted me to ask if i have to remove the whole headlight...
Last edited by bruiserinpink; Jan 27, 2008 at 02:50 PM. Reason: Automerged Doublepost
Old Jan 27, 2008 | 02:52 PM
TheCaptain's Avatar
They should be a plug and play, but it might be confusing, because they throw the ballast in there too. It should be as easy as fitting the right connectors to their respective parts (male/female).
In other words, they make them built one way only, so that you can't plug hids in without the ballasts.
Headlight harness > ballast harness > hid bulb.
You won't be able to screw it up like, Headlight harness >hid bulb ><ballast harness
Yes, he will have to remove the headlights.
Is this a two bulb HID, (HID low, halogen high)? or is it just an HID low (you won't have highs)? Or bi xenon HID (has a little roof that slides on the bulb)?
Hope this helps.
SSnRXP
Dec 4, 2015 11:02 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
dieGone
Sep 23, 2015 10:20 AM
Xenozx
Oct 23, 2007 09:59 AM
