high-flow 02 sensors..??
Old Sep 21, 2009 | 11:49 AM
averagewhiteboy's Avatar
What's the deal with high0flow 02 sensors? Are they necessary when running a header/dp etc or is it just a marketing ploy? I ran a standard set of sensors when I had my ZZP combo in, and still do with my GMPP catback, but I plan on doing another header/dp, so I want to use them if necessary. Don't want to run totally off. I will just do the front as I will do HPT and do the rear 02 delete.. If they are suggested, how much more is a high-flow cost-wise in relation to the standard one?
Thanks!
Old Sep 21, 2009 | 11:52 AM
ShortStack's Avatar
High flow o2 sensor?....
The o2 sensors do not hinder flow...
Old Sep 21, 2009 | 11:55 AM
I know that, but they advertise high-flow ones. I suppose that they can process the higher amount of airflow better?
Old Sep 21, 2009 | 12:03 PM
ShortStack's Avatar
You do not need to change out your o2 sensor... its just fine.
Old Sep 21, 2009 | 12:11 PM
Jn2's Avatar
Jn2
maybe u misunderstood high flow catalytic converter? no such thing as a high flow o2, stock ones are fine...
Old Sep 21, 2009 | 12:36 PM
I'm 99% positive I've seen it..? lol Dunno.. My front one seems to be reading off at times, so i'll likely just replace the front, then just do the rear delete with HPT then..
Old Sep 22, 2009 | 03:01 PM
ShortStack's Avatar
Reading off? How so?
Turbo6
Sep 30, 2015 09:14 AM
quickspec
May 23, 2012 07:16 AM
TommySSSC
Mar 18, 2009 01:21 AM
