How to: Approach Dealer on Brake Problems
Old Oct 16, 2006 | 12:54 AM
boostbalt's Avatar
Hey all,
I am asking for some advice on the best way to approach a problem I am having. So far my dealership has been good about adressing my concerns. I don't like to bring my car in unless I have to, and I really have to this time.
Basically this is what's up (please comment if you have had this):
Slowing down from around 50 mph (80km/h) everything is fine the car tracks true and doesn't pull right or left. I maintain the same brake pedal pressure, however, as the car gets down to about 30 mph (50km/h) it begins to pull aggressively either left or right. I find this very strange as I have not increased my pedal pressure, nor does it pull consistently to one side as one would expect from a bad Caliper. I am unsure if this is steering, suspension, or the brake system itself.
I want to ensure my description is specific and I do not want them doing excessive testing with my car. You know how eager a tech is to drive the crap out of these cars and that's exactly what I am trying to avoid. Do you think the above explanation is sufficient? How would you approach this situation with the dealer?
Thanks for your two cents!
Ryan
Old Oct 16, 2006 | 12:55 AM
boostbalt's Avatar
PS: this happens on both even surfaces which are not slopped and of on sloped surfaces. On sloped surfaces the pull is much harder then if I simply lift my hands off the wheel and let the car track with the road's contour.
Ryan
Old Oct 16, 2006 | 08:46 AM
celicacobalt's Avatar
good luck, my dealer basically said to go scrw my self after having them sand down the rotors twice they wont touch my brakes anymore
Old Oct 16, 2006 | 12:36 PM
mugencivicsi's Avatar
when i first got my cobalt, it happened 2 weeks after driving.
service writer (who is a ****) told me the slight shaking was normal, and that the rotors where just cooling down, and thats why i got come shake..
well i brought it to the dealer 3 more times about it, he said to wait a bit, i took it to another dealer and he said i should have had it resurface a while back, so they resurfaced it under warrenty, 4months later, same thing and the surefaced them again, now im over my 30000km break warrenty..
all i have to say is slotted/drilled in all 4 corners is on its way........
Old Oct 16, 2006 | 01:43 PM
BigAl's Avatar
I've had similar problemes.
First, the dealer turned my discs, did not want to replace them. This is at 17000kms. The car would shake everytime I brakes.
Then it started to pull to the left, so they aligned it. GOt it back, it was now pulling to the right. Went again, it still pulled to the right. I guess third time is the charm, cause they finally fixedit. The rotated the tires a few times, then realigned it for the 3rd time.
Good luck
Old Oct 16, 2006 | 01:51 PM
BooSSted's Avatar
If you don't want the tech to drive the hell out of your car. Go with him. They can't deny you as a passanger in your own car, haha.
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Sep 27, 2015 08:53 PM
