How hard is it to install the SS lip kit
Old Nov 21, 2008 | 01:53 PM
chrism0589's Avatar
Question How hard is it to install the SS lip kit
i want to buy the front n rear lip and the side skirts from the ss but i want to know how hard it would be to install them
edit:
also to intsall the ss front bumer. the rear one is the same right?
i have a 07 ls
Old Nov 21, 2008 | 01:59 PM
CobaltCpe's Avatar
not hard as i have taken many bumpers off and put on lip kits before. Just find the correct bolts and clips and pull them out and there comes your front bumper off. Lip kits usually screw somewhere and are held by two way tape. As long as you have good knowledge in cars and are hands on you should beable to figure it out.
Old Nov 21, 2008 | 02:01 PM
EXsoccer1921's Avatar
rear lip would be the most difficult of the two, but still not that hard, just get a dremel with a small cutting wheel to get the slits in the bumper to slide in the lip
Old Nov 21, 2008 | 02:05 PM
deuce's Avatar
there is a video how to for this, you need to drill holes, but they are evidently marked on the inside of the bumper
edit: they are marked on the SS bumper, i see you have a base...nevermind
Old Nov 21, 2008 | 02:06 PM
chrism0589's Avatar
How Much Do U Guys Think It Would Cost If I Were To Have Someone Do It??
Old Nov 21, 2008 | 02:07 PM
Jplaya023's Avatar
This is the correct way...i believe if you search for there is a How To. It takes time but all you need is basically a dremel and about a day. Good luck!
Old Nov 21, 2008 | 05:17 PM
ace921000's Avatar
im thinking of doing this too. yeah i read the how to. you need to cut slits in your front bumper to mount the lip. doesnt look to terribly hard..
Solaris99
28
Mar 15, 2017 01:22 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 28, 2015 12:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
