How high can we rev rhe LSJ before valve float?
Old Jul 4, 2007 | 06:34 PM
Onyxd04Redline's Avatar
7200? 7500rpm?
Old Jul 4, 2007 | 06:38 PM
p7x's Avatar
p7x
somewhere in the the 7200-7400 range from what I have heard theres a thread about this somewhere on here and someone posted the specs on the Lsj valves.
Old Jul 4, 2007 | 06:40 PM
jimbos'ss's Avatar
mine starts miss firing at around 7100.
Old Jul 4, 2007 | 06:41 PM
LScoupeTUNER's Avatar
well...a non-*** shouldnt need to go that high...ricer bitch...JK JK dont hurt me it was a joke...
Old Jul 4, 2007 | 07:01 PM
Only reason i ask because hp would continue to climb if we were able to rev to 7500rpm. Thanks guys
Old Jul 4, 2007 | 07:11 PM
3fo893013L's Avatar
I've have my rev limiter set to 7100RPM. I shift about 3 seconds after my shift light on my interceptor lights up at 6800RPM. 7,000 should be plenty. You do notice a difference in power with it higher but I cannot imagine it's worth the explosion your going to create making it go that high.
an0malous's Avatar
are you sure thats not your rev limiter LOL
Old Jul 4, 2007 | 07:15 PM
SilverBalt13's Avatar
The highest I have seen it run consistantly is 7400..... I think the valves float at that rpm though. I ran mine at 7200 alot of times with no issues.
Old Jul 4, 2007 | 07:18 PM
Doc's Avatar
Doc
I have my limiter set at 7400, I've come close a few times without any issue.
When I had the stage 3 pcm in, I set it to 7600 and it worked just fine.
Old Jul 4, 2007 | 07:21 PM
Damn 7600! Thats huge haha.....
Old Jul 4, 2007 | 07:25 PM
Shortbus's Avatar
Thats what she said!
Old Jul 4, 2007 | 07:27 PM
Doc's Avatar
Doc
I don't set it to hit it, I set it high so I don't. Make sense..?
Old Jul 4, 2007 | 08:12 PM
Has anyone ever dyno'd to 7500rpm? I know the powerband keeps pulling to 7000rpm so 500 more would probably yield a few more ponies.
Old Jul 4, 2007 | 08:17 PM
DaREDss's Avatar
nobody should go over 7200 , but with valve springs you can go 7500...
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/parts-needed-7-5k-rpm-53537/
Old Jul 4, 2007 | 08:19 PM
Mikey851's Avatar
lol ; Imagine if you didn't know what a rev limiter was and you hit it for your first time. You would say to yourself, "Awww ****". lol
Old Jul 4, 2007 | 08:20 PM
Ya it makes sense. I dont know if your tach blows as much as mine does. I have my rev limiter set to 7200 and on the tach it reads 7k-7100 rpm's when it will hit the rev limiter.
Old Jul 4, 2007 | 08:22 PM
DaREDss's Avatar
i think the gauge is a little slow mine does that too i just shift a split second before i hit 7rpm
Old Jul 4, 2007 | 08:24 PM
Doc's Avatar
Doc
Another reason I set it higher. The time period between actual engine rpm and vcm recognition are off sometimes so its better to play it safe.
If anyone decides to run the engine above 7k constantly, I'd strongly suggest changing the valve springs to begin with, but doing it occasionally shouldn't hurt anything.
Old Jul 4, 2007 | 08:28 PM
jimbos'ss's Avatar
no doc set my fuel cut at 7200, funny thing is i still seem to hit the rev limiter guess i need driver mod stage 5 now.
Old Jul 5, 2007 | 12:49 AM
InfinityzeN's Avatar
I only hit the limiter once. Of course it was when I was getting on it hard in 1st.
*punch gas* ROOOMMM-put-put-put "What the hell? That was quick!"
Old Jul 5, 2007 | 12:58 AM
ItalianJoe1's Avatar
I like the limiter. Sounds cool, and makes the car throw flames. Not good for racing though, but fun when driving around on wet roads like tonight. Waaaaaaa-BAP-BAP *shift* Waaaaaaaaaa BAP-BAP-BAP
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Trav3480
Sep 28, 2015 02:46 PM
Sep 28, 2015 12:51 PM
