How are the high mileage SS/SC's holding up?
Old Dec 23, 2014 | 06:00 PM
chris88z24's Avatar
I'm at 105,000 currently. No oil consumption. Oil changed per OLM with Mobil-1 5W-30 and NAPA Gold oil filter. Everything else maintenance wise is done according to the schedule in the owners manual. Maybe a little sooner.
Old Dec 23, 2014 | 06:07 PM
umrdyldo's Avatar
I assume you have fixed all of the probably suspension failures. Shocks, struts, CABs, etc.
Old Dec 23, 2014 | 06:29 PM
chris88z24's Avatar
Struts, Shocks and CAB's were done around 50k-ish. I also added Eibach Pro-Kit springs at that time.
Old Dec 23, 2014 | 06:59 PM
umrdyldo's Avatar
If these cars aren't heavily modded and well maintained, they should last to 200k no problem.
Oh and a little luck.
Old Dec 23, 2014 | 07:01 PM
06cobaltncng's Avatar
im now having to change out my clutch master I believe. thats after destroying a gmpp clutch and trans case.
Old Dec 23, 2014 | 07:10 PM
blueLNFftw's Avatar
105k
clutch and related at 60k
lca, tierods, and all related (front and rear) at 75k
timing tensioner at 90k
tires
brakes 2 times (rotors and pads)
honestly, it has been reliable as **** and never had a big or odd failure. All routine stuff.
and my car has been on GMSTG2 for the first 50k, Trifecta Stage 2 for about 20k, and a 2.9 with 60's for the rest of the time.
Old Dec 23, 2014 | 09:54 PM
double clutch's Avatar
211k miles. Still running like a dream
Old Dec 23, 2014 | 11:57 PM
Tsbbzm's Avatar
Jedi Master
^Dang.. I'm at 69,000 never had to do anything other than change a spark plug
Old Dec 24, 2014 | 12:03 AM
I swear the previous owner had to do a rebuild or something because this thing runs way too well for that many miles
Old Dec 24, 2014 | 12:07 AM
Tsbbzm's Avatar
Jedi Master
Or its the cobalt from god
I know mine is not really considered high miles or at least not in my book, but the way mine runs I would trust it to drive to California and back no hesitation
Old Dec 24, 2014 | 12:54 AM
blueLNFftw's Avatar
I did the clutch because the crap LSJ TOB blew apart.
I did the suspension because I switched everything to MOOG greasable.
I did the LCA because I installed LNF control arms and solid CABs.
The only thing the car ever needed was a clutch. The rest was wants and maintaining it. My LSJ will see 200k if the new owner takes care of it like I have.
Old Dec 24, 2014 | 01:43 AM
Spawne32's Avatar
everyone knows that satan designed this car
Old Dec 24, 2014 | 07:25 AM
Staged07SS's Avatar
Administrator
Administrator
What's this high mileage thing you speak of....?
lol
Old Dec 24, 2014 | 08:42 AM
freakta's Avatar
I'm at 72k and this is the 4th engine and 3rd transmission. But only because the original owner beat the car to death
Old Dec 24, 2014 | 09:43 AM
bnutz's Avatar
Just about to hit 59k and just replace the shocks and that's about it also threw in the sport lines
Old Dec 24, 2014 | 09:45 AM
Blowncavy's Avatar
I drove mine to nebraska to florida 4 times in mine
Old Dec 24, 2014 | 10:15 AM
HIValicious's Avatar
Traded mine in back in December 2012 with 105K miles. Only thing I replaced were the brakes right before I traded her in. Everything else was perfect. Nothing else was wrong. Although, I did replace a couple bulbs that went out in the lights, but that's it. Oil change & filter, every 3500 to 5K miles.
Old Dec 24, 2014 | 02:06 PM
Viperoni's Avatar
My IRL hasn't been as problem free as my Toyota Echo was, and it's only at ~90k so far, but it's a very different car too.
Old Dec 25, 2014 | 11:16 AM
06blackg85ss's Avatar
194000 miles on mine, only stuff I changed was because I upgraded.
only major overhaul was last year at 165k miles did new cltuch, brembo brakes, lnf suspension, new control arms and powell cab's.
decided to change out the motor a few weeks ago, definitely didn't have to as it ran perfectly fine and I beat the **** out of it. motor looks like new internally just leaked a bunch of oil
Old Jan 8, 2015 | 11:32 AM
chris88z24's Avatar
Where did it leak from?
Old Jan 8, 2015 | 11:58 AM
UnkleRaRa's Avatar
Just over 86,000 miles
Only repair related issues ive had was the flex pipe on the downpipe replaced in the fist year I owned it.
I need to install the new CAB's I have.
Obviously preventative maintenance like oil changes, TB cleaning, etc..
Otherwise every change has been just because I wanted to (spark plugs, pads n rotors, intake (back to stock now)).
She's been good to me, but i like to think its cause I've been just as to to her!
Old Jan 8, 2015 | 01:47 PM
everywhere lol
valve cover, exhaust cam end cap, oil pressure sensor, and oil cooler
Old Jan 8, 2015 | 01:59 PM
chris88z24's Avatar
everywhere lol
lol I think I am getting the oil pressure sensor and/or oil cooler leaks. How much did it lose?
Old Jan 8, 2015 | 02:10 PM
MonsterDude72's Avatar
Sitting now at 91k and i have a spark plug blow out the head. Other than that nothings wrong with it.
Old Jan 8, 2015 | 02:11 PM
umrdyldo's Avatar
Had they ever been changed?
