How to replace front bumper??
Old May 20, 2006 | 09:14 PM
tiny's Avatar
I gotta put on a new front bumper (killed a stop sign), and I was wondering if anyone could give me some tips, or a how to
i know a bunch of you have installed body kits, so help me out
thanks ahead of time
Old May 22, 2006 | 01:01 PM
tiny's Avatar
bump, anyone?
Old May 22, 2006 | 01:03 PM
snobird's Avatar
i could help tiny but i wont be able to take pics its not too hard to remove it how is your car doing fom the truck that hit you is everything ok as i get parts cheap and always willing to help out members
Old May 22, 2006 | 01:08 PM
snobird's Avatar
headlights goota come out and part of the grille the top part un bolts with thoose plastic screw thingies and i belive ther is a few bolts on the fender wheel well area ill go take a peek and come back
Old May 22, 2006 | 02:23 PM
fljohnboy's Avatar
I didn't remove the headlights out when I did mine. On top in engine compartment there are a few push in screw clips. Under car the same. You will have to pull some of the same clips out from the inner wheel liner, easier with wheels removed. There are screws you need to remove once the liners are out, you will see these. Not that hard of a job once you start taking things out you will see what has to be done next.
Old May 22, 2006 | 02:27 PM
Tomtwtwtw's Avatar
Don't want to hijack *too* bad, but my other thread got ignored / lost in all the other posting.
I need to replace the rear bumper piece on my mom's LS Sedan. Someone parked into her only 10 days after she took it home and literally ripped a hole in the side of it, where there's no brace underneath. Anyone know where I can get that cheap as possible? I'm sure I can replace it myself.
Old May 22, 2006 | 02:44 PM
skoshi130's Avatar
Where the front bumper meets the fenders. There are (3) 10mm bolts, on both sides. Remove the bottom bolt completely and loosen the other two; they hold plastic clamp brackets in place. Then remove the top tab fasteners, and the two from the bottom. The area where you would replace your foglights there are (4) 7mm screws toi remove on each side. and (3) in each fender well. It is actually easier to do this by using a jackstands. You would never have to pull the wheels off. I will try and get some pics ASAP if needed
Old May 22, 2006 | 02:54 PM
Beck's Avatar
insurance should cover this without upping her rates no? or they didnt leave a note?
Beck's Avatar
oh yea also you might want to look into a pick and pull type place for a wrecked cobalt.. but the odds of finding one are pretty slim
Old May 22, 2006 | 07:05 PM
tiny's Avatar
hmm, itll be tough to find one, i would contact some ppl on here that have body kits, and see if you can get their stock bumpers, that's what I did. I got really lucky!
thanks, that helps a lot!!
im gonna turn this into a how to!
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
grampss
Sep 27, 2015 08:51 PM
