How To Wire This?
Old May 1, 2006 | 09:38 AM
mkulrey13's Avatar
How To Wire This?
Well i plan on installing some of my underglow today since its kinda nice out and was wondering after everything is all screwed in and such how do i go about wireing this thing to the battery... If someone could explain the process would be awesome i kinda have a fear with electricty after seeing my grandfather get shocked from installing a light socket thing in the wall. Thanks & please dont say i shouldnt do it... or underglow is gay... its my car not yours if you dont want to help lol dont. Cant learn anything if i dont try thanks for anyone that helps!
Old May 1, 2006 | 09:43 AM
Chevypowered's Avatar
You'll probably want to wire it into the fuse box and have a toggle switch? I would look for an empty spot in the fuse box in the engine compartment or one in the fuse panel on the right side of the center consle(sp?). How many amps does this kit draw?
Old May 1, 2006 | 09:47 AM
mkulrey13's Avatar
Well i have a wireless remote for it as well but yes that would seem safer anyhow let me go look brb
Old May 1, 2006 | 09:53 AM
mkulrey13's Avatar
"The 12 volt electronic neon tubes drawr only 6 amps. an 8amp in-line fuse is provided"
the power outlets total (5A)
how would i go about wireing this up to the fuse box then if that is safer/easier
Old May 1, 2006 | 02:40 PM
BlackSS05's Avatar
ok fastest way is going through the trunk straight to the battery. what i did was drilled a whole out there is a little tab underneath the spare tire that goes underneath to the car. then you run all of the wires into the trunk to the battery. run two wires up to the spot where you want the switch. connect both to the switch. one will run to the neons or the power source of the neons and the other one will go to the battery.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
