I had a little boo boo with the jack...
Old Nov 25, 2009 | 10:40 PM
RooTBeeR's Avatar
WARNING!!! Fail In Progress!
...i got in a hurry rotating my tires, had the jack in the middle of the axle beam from the back and it slipped off, hit the (EDIT)charcoal canister. What appears to be oil has leaked out and now the fuel tank pressure sensor is hanging there loose fml!
Old Nov 25, 2009 | 10:41 PM
madmark's Avatar
fuel pump is on top that looks like the evap canister
whyyoumadson?'s Avatar
thats not the fuel pump assembly. that is your charcoal canister
Old Nov 25, 2009 | 10:42 PM
Tomtwtwtw's Avatar
Old Nov 25, 2009 | 10:46 PM
RooTBeeR's Avatar
lol, those were under the front...i was still just getting it off the ground when it slipped that why its not totally ripped off or crushed haha
...well then thats good news for me at least...i was looking for a diagram/pic that would tell me what it was exactly but i was having trouble
Old Nov 25, 2009 | 10:53 PM
madmark's Avatar
the hanging wire is possible purge silonoid
Old Nov 25, 2009 | 10:54 PM
HB_SS/TC's Avatar
you should see what I did to my Hahn IC when the jack slipped on me
Old Nov 25, 2009 | 10:58 PM
madmark's Avatar
or maybe fuel tank pressure sensor...... but idk all i can see is cracked evaperative canister
Old Nov 25, 2009 | 11:00 PM
D4u2s0t's Avatar
if you don't know, you're not supposed to jack the car from the torsion beam. and in general it's never a good idea to jack a car from something that moves. (not sure if you were just being lazy, or didn't know that.)
Old Nov 25, 2009 | 11:01 PM
madmark's Avatar
you CAN jack from the beam but i think he didnt center it
Old Nov 25, 2009 | 11:02 PM
D4u2s0t's Avatar
i'm not saying that you can't, i'm saying that you shouldn't. use the appropriate jack points, and the car gets up just as quickly, and there's much less risk of the jack slipping off.
Old Nov 25, 2009 | 11:07 PM
madmark's Avatar
all im saying is paying 5 dollars for a rotation would of been alot better than the 400ish to fix this
Old Nov 25, 2009 | 11:08 PM
where r we suppose to rise the rear on this car? thats the only strong spot i saw haha
Old Nov 25, 2009 | 11:09 PM
D4u2s0t's Avatar
there's a how to by halfcent that tells you how to jack the car.
madmark's Avatar
its a good point to raise from but you have to center that jack on the beam, which you didnt do and found what can happen. either that or on the rocker panel behind the side skirts
Old Nov 25, 2009 | 11:12 PM
codytheoutlaw's Avatar
use the floor pan.
Old Nov 25, 2009 | 11:23 PM
RooTBeeR's Avatar
ive rotated my tires plenty of time, never had an issue before, but yeah like i said, was in a hurry, and didnt get the jack under the beam far enough so it came off
Old Nov 25, 2009 | 11:25 PM
Originally Posted by codytheoutlaw
use the floor pan.
haahahaha tell the masses they must know the truth
Old Nov 25, 2009 | 11:43 PM
D4u2s0t's Avatar
it's never a good idea to jack from a moving part on a car... yes, the torsion beam works great... but you shouldn't be using it.
Old Nov 26, 2009 | 10:03 AM
BlueStang's Avatar
The last time i had my tires rotated was at the dealer for $20, and I got a free cup of coffee and the car washed while I waited. A lot easier than doing it myself
Old Nov 26, 2009 | 10:19 AM
ddsscobalt's Avatar
damn im sorry!
Working at a car shop FTW! paid 10 bucks for snow tires swapped on my rims, and an alignment
and i used a lift!
Last edited by ddsscobalt; Nov 26, 2009 at 10:19 AM. Reason: Automerged Doublepost
Old Nov 26, 2009 | 10:27 AM
Permafried-'s Avatar
There is, but it recommends lifting one side of the rear at a time just in front of the rear control arm mount. I actually use the mount itself when changing my tires over to winters, it's only on the jack for maybe a minute so jackstands in this case are pointless. As for rotating though, I honestly don't know how to get the entire rear of the vehicle off the ground in one shot.
The front you can use the engine cradle cross-member; make sure you're good and stable though (or use the little "notch" just to the left of centre) if it slips even a bit you better have a backup radiator handy. As for the rear, as he said you should NOT be using the torsion beam, but that still begs the question "where do you jack this car in the rear to get both wheels off the ground at the same time"....I think the answer is you don't without using that torsion beam...or am I missing something?
Old Nov 26, 2009 | 02:09 PM
jmz250's Avatar
I've always found it easiest to just do one side at a time (assuming you have directional tires here). Just lift it up from the stock jack points, switch tires, go to other side, repeat. Safest way as far as I can tell.
Old Nov 26, 2009 | 02:22 PM
mofofernando's Avatar
^^ but ya dude that sucks. id probably end up doing the same thing. thats why im glad i get my tires from americas tire so they rotate them for free
Old Nov 26, 2009 | 02:30 PM
2x ^^
