I had a little boo boo with the jack...
WARNING!!! Fail In Progress!
...i got in a hurry rotating my tires, had the jack in the middle of the axle beam from the back and it slipped off, hit the (EDIT)charcoal canister. What appears to be oil has leaked out and now the fuel tank pressure sensor is hanging there loose fml!
lol, those were under the front...i was still just getting it off the ground when it slipped that why its not totally ripped off or crushed haha
...well then thats good news for me at least...i was looking for a diagram/pic that would tell me what it was exactly but i was having trouble
if you don't know, you're not supposed to jack the car from the torsion beam. and in general it's never a good idea to jack a car from something that moves. (not sure if you were just being lazy, or didn't know that.)
its a good point to raise from but you have to center that jack on the beam, which you didnt do and found what can happen. either that or on the rocker panel behind the side skirts
ive rotated my tires plenty of time, never had an issue before, but yeah like i said, was in a hurry, and didnt get the jack under the beam far enough so it came off
it's never a good idea to jack from a moving part on a car... yes, the torsion beam works great... but you shouldn't be using it.
damn im sorry!
Working at a car shop FTW! paid 10 bucks for snow tires swapped on my rims, and an alignment
and i used a lift!
and i used a lift!
Last edited by ddsscobalt; Nov 26, 2009 at 10:19 AM. Reason: Automerged Doublepost
There is, but it recommends lifting one side of the rear at a time just in front of the rear control arm mount. I actually use the mount itself when changing my tires over to winters, it's only on the jack for maybe a minute so jackstands in this case are pointless. As for rotating though, I honestly don't know how to get the entire rear of the vehicle off the ground in one shot.
The front you can use the engine cradle cross-member; make sure you're good and stable though (or use the little "notch" just to the left of centre) if it slips even a bit you better have a backup radiator handy. As for the rear, as he said you should NOT be using the torsion beam, but that still begs the question "where do you jack this car in the rear to get both wheels off the ground at the same time"....I think the answer is you don't without using that torsion beam...or am I missing something?
I've always found it easiest to just do one side at a time (assuming you have directional tires here). Just lift it up from the stock jack points, switch tires, go to other side, repeat. Safest way as far as I can tell.
