The InfinityzeN Car Project
Old Sep 22, 2006 | 04:25 PM
InfinityzeN's Avatar
*Edit* Forgot a couple of things
Allright, I'm sure most of you know I'm over in Iraq right now and I'm sure a couple of you even know that I've worked out ordering a new '08 Cobalt SS/SC with a dealership so I can pick it up ether the day I get back or the day after. And that they can get me a really good price, including install of after market parts.
So here is where I'm going to need some help. Since I'm in Iraq and alot of sites I don't have access to, plus some that I could have access to I can't actually display (like Cobalt Addition), I'm going to need some help choosing things to add to the car.
Right now, here is a rough list of what I'm looking at having installed in the car when I pick it up. Cash/Trade-in total can be up to around $30k, so I shouldn't have any problem getting what I want.
Dealer Install
Intake (not sure if I want a full one or a drop in filter)
GMPP Stage 2
Pulley Boys 2.8" Pulley (possibly, I'm back and forth on it)
Intense Supercharger Porting
1 step colder plugs
HPT tweaked tune
GMPP Manifold (I've been seeing people have too many problems with others)
Dezod Motorsports 2.75" exhaust
DC Sports CS-1 Front Strut Bar
Torque Forward Cobalt SS Rear Support Bar
Ingalls "The Stiffy" Engine Torque Damper (set fairly soft)
Progress Technology Rear Anti Sway Bar
Eibach Sportline Springs
Intense Suspension Package
LFP Dual-Pass Heat Exchanger (DIY if no kit out when I order car)
Short Throw Shifter (Possibly, looking at hurst)
GM Brushed Alum Trim kit (the one with the heated seats switch hole)
GM Brushed Alum Petal kit
Stripping (? Not sure here, Pin, racing, don't know)
Sun Hyper Hot InaZma (Cobalt Version)
Sun Hot InaZma ECO (Cobalt Version)
Sun Hyper Ground
Optima Yellow Top battery
First thing at home Install
Voodooboost MBC, Dual Stage (thinking 12.5lb and 17~18lb, switch in "heated seat" hole)
AVS Door Visors
AVS Rear side window covers
Vision Bulbs Xenon Interior Bulbs
Headlight Bulbs/Foglight Bulbs (Can't find the thread with the ones I liked, slight blue-white, NOT HIDs)
Lock covers (for doors & truck, painted)
Later Install/Work
Full Audio system
Spec Stage 3+ Clutch & Flywheel
RK Sport Spoiler (slight possiblity)
RK Sport Ram Air Hood (very slight possiblity)
ShowMe Street Customs Covers (Door Sill, Fuel Rail, and Valve Cover)
Headlight (housing pointed body color)
Tail lights (nightshade tinted, brighter bulbs)
Marker lights (nightshade tinted, brighter bulbs)
Calipers (painted body color or Black)
Rim Center Caps (Custom Design, getting the brushed rims instead of gun metal)
Silicon Tubing (replace all stock, most likely gloss black)
So help me out here guys. I know some of the stuff will be up in the air until we get more info on the '08s, but I'd like to have a pretty good list done up and just tweak it as the time comes up to order it. And I might bring up the audio in a seperate post.
Old Sep 22, 2006 | 04:31 PM
CTCOBALTSSS's Avatar
I thought the 2008 Cobalt was going to be Turbo. Is this not true?
Old Sep 22, 2006 | 05:01 PM
That is a rumor running around man. No one knows until GM actually announces it.
And if they do switch it, then I'm just going to go with a Pontiac Solstice GXP...
Old Sep 25, 2006 | 06:23 PM
Ok, someone help me out here. I need some suggestions on what I'm getting and other things I could try or change. Come on, help me out here.
chefhhr
Oct 26, 2015 10:36 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
63 Nova SS
Sep 12, 2015 11:21 PM
