Installed engine block heater today/first oil change
Old Sep 12, 2005 | 10:34 AM
05BlackSS's Avatar
I bought a GM engine block heater some time ago and figured when I got around to doing my first oil change I would install it. It is a bitch to do from above so while the car was up on the hoist, I had my mechanic put it in for me. Fits perfectly. Also, I have seen alot of debate about how much oil the car takes. Since in Canada we go by litres, its exactly 6.4L
I did a complete drain, let it sit for 20 minutes, then put in 5.4L of oil, dipstick read full, started up the car for 15 seconds, shut it off, checked oil level again, went right back down below the first notch. Added another litre and we are in business. I also had my calipers/caliper brackes buffed by a high speed plastic bit. Gave them a nice shiny look, then I clear coated them. Was a great weekend for the Cobalt SS/SC
Old Sep 12, 2005 | 11:08 AM
betterthanbad's Avatar
That's a cool idea with the calipers. I've got to see that. Did you do it yourself or while you were at the shop?
Old Sep 12, 2005 | 11:11 AM
05BlackSS's Avatar
I did it while I was at the shop. My guy is a single man operation, a good friend, so I do whatever I want when I am there. Took the wheels off, buffed them up, gave them 2 coats of clear coat. Will take a picture tonight and post it.
Jason
Old Sep 12, 2005 | 11:26 PM
BJC's Avatar
BJC
You didn't happen to notice how many watts or amps the block heater uses did you?
Old Sep 13, 2005 | 08:18 AM
05BlackSS's Avatar
No, but I can check. It's just a regular 120 plug on the end.
Old Sep 14, 2005 | 08:35 AM
BJC's Avatar
BJC
Ya I know. The base 2.2 (that's what I have) in Canada comes from the factory with one. We get this instead of AC included here. A $50 part instead of a $1000 part.....seems fair
chefhhr
Oct 26, 2015 10:36 PM
dieGone
Sep 23, 2015 10:20 AM
OrngBalt
Sep 16, 2015 07:45 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
