interior trim question
Old Sep 11, 2008 | 09:47 AM
blk ss/sc 1's Avatar
ok... im finally going to paint my chipped up trim pieces.. Before i get started I wanted to know if there is a trick to getting them out? Does anyone know if they clip in or what?
Old Sep 11, 2008 | 09:50 AM
SilvrLT's Avatar
you have to remove the glove box and the drivers side kick panel then they just pop out. take your time b/c they are in there really tight but they will come out
Old Sep 11, 2008 | 09:57 AM
what about the pieces on the door?
Old Sep 11, 2008 | 09:59 AM
SilvrLT's Avatar
the window switches have a screw in side the grab handel part then they just pop out as well
Old Sep 11, 2008 | 10:00 AM
thanks
Old Sep 11, 2008 | 10:11 AM
SilvrLT's Avatar
no problem, good luck
Old Sep 11, 2008 | 10:18 AM
umrdyldo's Avatar
I use a small pry bar and get it behind the panels and pull
Old Sep 11, 2008 | 11:05 AM
CheviSS's Avatar
Have fun with the door ones.. i busted both the clips off mying.. and still had to pry the dang things off.. and busted all the clips on all the other ones... pretty much destroyed everything.. luckily i work at where they carbon fiber them ..
Be patient though. I think they make a tool to make the clip removing easier.
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
