just curious
Old Sep 23, 2008 | 01:58 PM
blackedout06's Avatar
just curious
does anyone have the problem that when you wash your cobalt and dry it, water seems to keep coming out in between the driver's side back fender and the back window. cuze it'll leek outta mine for hours after i wash and dry it. It pisses me off when it leaves water spots down the back fender.
Old Sep 23, 2008 | 02:00 PM
LamboW9's Avatar
pull it up on a hill slightly an park it there an dry it then....the water has to run out places an thats one of the spots
Old Sep 23, 2008 | 02:02 PM
SKCobalt's Avatar
the water is running from the seal groves in the roof down the side of the window. The parking on a hill trick will help speed the water coming out when drying. You could do a quick chamois and then a boot around the block and do your final drying. that seems to work for me!
Old Sep 23, 2008 | 02:05 PM
I usually just drape a microfiber towel over that spot when I'm done and let it sit for a little while, then just dry it when I'm done, but I dont want to wait for that long for the seal to dry out in there.
Old Sep 23, 2008 | 02:08 PM
LamboW9's Avatar
a hair dryer will help push the water out if necessary
Old Sep 23, 2008 | 02:14 PM
well thanks for some of the suggestions. if anyone has more just let me know.
Old Sep 23, 2008 | 02:32 PM
Ducky22287's Avatar
Haha I have the same problem, also where the side mirrors connect to the car and where the wing connects to the trunk. All the lights on the back end as well.
Old Sep 23, 2008 | 02:35 PM
BowTieTillIdie's Avatar
After you wash it and get it ready to dry. Grab your air compressor and blow out the water in the crevices. ( if you wash your car at home ) I have to do this on all cars to prevent water in trapped areas from leaking out after you just spent 4 hours on it
Old Sep 23, 2008 | 05:53 PM
I thought of the air compressor but it's on my list of "things to buy." water gets built up in the inserts at the bottom of the rear bumper too so that lip at the bottom always looks like ****. I always clean that part again after i drive it a bit.
I know it, I hate all those spots.
Last edited by blackedout06; Sep 23, 2008 at 05:53 PM. Reason: Automerged Doublepost
Old Sep 23, 2008 | 07:01 PM
wardzach2007's Avatar
Its normal. Just open your trunk and dry it off with a shammy.
Old Sep 24, 2008 | 02:17 PM
rukkee's Avatar
I use a leaf blower on that spot ,along with the mirrors, back bumper , marker lights, front grill and the door sills. I never get any water run off when i go for the first drive after a wash now, and use about half the amount of micro fiber towles per wash. It also works great on the tires, blow the water off and you can use the tire dressing right away.
Old Sep 24, 2008 | 03:53 PM
gapsrollin's Avatar
mine comes out on the two blinkers/ door handles and lights just blow an the water comes out
Old Sep 24, 2008 | 05:55 PM
so what would you guys say is better, a shamois or microfiber towels?
Old Sep 24, 2008 | 06:23 PM
Old Sep 24, 2008 | 06:38 PM
joemama's Avatar
sham wow all the way
and btw in washington its about to be illegal to wash your own car at home..
Old Sep 25, 2008 | 07:45 AM
What! why? I dont see how they could do that. Thats some dumb ****!
ThoR294
Sep 28, 2015 05:31 PM
goaliemo
Sep 28, 2015 01:37 PM
TurboWood
Sep 28, 2015 05:10 AM
Shane H
Sep 20, 2015 11:56 AM
