key fob
key fob
hey guys
i was wondering where i could get a new key fob othe then the dealership due to my lock button dont work anymore but the rest of the buttons work jus fine....i didnt know if we could get them anywhere else but if a can stay away for the dealership that would be aewsome
thanks
thanks
hey guys
thanks
thanks
Or this if you don't have a remote start button:
You can always just use a hole puncher to cut a few circles out of a piece of cooking foil and fixate it inside the button on the inside to act as a conductor. Problem solved. No need to buy expensive new remote if the fix is easy. Went through it with my factory fob before I went with aftermarket alarm with remote start, which replaced my fobs with fancy LCD/LED screen ones. Worked well for me.
There's nothing wrong with doing it cheaper than the arm and a leg that the dealer will charge you... You probably have them change your oil too, eh? And wiper blades? EDIT: reybalt, just saw your join date and post count. Shoulda known. welcome to the forum.
One of my fobs stopped working during the winter to in lock my doors. Everything else was fine. So I did like suggested above and I out tin foil under the buttons. And it works perfect. Its been over 7 months and it still works perfect. I bet ghats all you need to do too. No need to buy a new one.
Both my fobs stopped working. Tried the tricks to make em work again with no success. Ordered fobs off ebay. Proper part# and the whole bit. Brought to a dealership and it wouldn't sync at all. Tried a stock GM fob, boom no problem. Just a little FYI.
satisfied
Oct 19, 2015 12:35 AM
