Keyless Entry Remote FIX
Old Jan 22, 2010 | 04:54 PM
mrfitz's Avatar
Hey guys. I fixed my keyless entry remote (stock) and it works perfectly now. No more intermittent failure... perfect.
I typed up a "how to" on it 2 weeks ago.....
The problem is.... it still hasn't shown up in the "how to" section.
Old Jan 22, 2010 | 05:09 PM
shawn672's Avatar
2 different cobalts with the stock remotely entry/start, and ive never had an issue. i was also unaware of a common issue with the remote keyfob. what kind of symptoms were you having?
Old Jan 22, 2010 | 05:13 PM
riko540's Avatar
I had an issue with mine, turned out to be faulty solder joints on the battery connector.
Old Jan 23, 2010 | 12:17 AM
Nighthawk243's Avatar
Yeah, it is the solder joints. If you press the buttons too hard or are not careful replacing the battery, the battery clip loses connection. Two methods of fixing it are to either resolder it with a proper solder joint, or to just use something to shim the clip to make it hold connection.
Old Jan 23, 2010 | 12:28 AM
mrfitz's Avatar
Exactly. I resoldered them. Perfect now. The factory solder was brittle and didn't bond right, almost like a cold solder joint.
Anyway, I posted pics and such for people who don't know what they're looking at on a circuit board.
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jmelton327
Sep 26, 2015 10:04 PM
