Leaky leaky
Leaky leaky
Anyone had a problem with water leaking in the rear. I'm not sure if it's the back window. Or the quarter window. I'll get a run of water on the trim inside. But it actually puddles up in the trunk. Not sure which window. It leaks when it sits. Once I start driving I don't think it comes in anymore.
Check the drain tubes in the trunk if you have a sunroof, there is one of them on each side, mine was unplugged and that caused the water to go in the trunk where the spare tire was
Yeap, the drain tubes are right behind the carpet on the sides, if you have a subwoofer,it will be right behind it and the carpet, but they are easy to find, just make sure they are not clogged up or removed
speedracer6g
May 31, 2014 08:15 PM
