Lil Blacky’s official TVS build thread(long post)
Old 02-09-2018, 10:21 AM
  #351
chevygirl2006's Avatar
Originally Posted by HGT
How are the dual fans doing?
They work good
Old 02-09-2018, 12:55 PM
  #352
Henry3959's Avatar
Im spinning it to 8k and before the balance shaft deletes I didn’t have those interior vibration when accelerating. I’ve had the motor mount and insert for a while
Could the vibration be from something else. I thought the video sounded very noisy. All I hear is my supercharger.
Old 02-09-2018, 01:07 PM
  #353
jdbaugh1's Avatar
I spin to 8k too just saying anything over 7,500 they say you need to do something with BS either delete or neutral. I'd look into the vibration more to and make sure what it is because the only difference I notice before and after was I could feel vibes in the steering wheel at idle. Under acceleration I noticed no difference at all. You can't even notice any differences from in-cab videos on mine.
Though I supposed the vibrations COULD be strictly from your BS delete and the effect is just amplified because of your motor mounts. I only have a rotated front mount and it is 1-piece rubber bushing non-voided. Running stock upper mount.
Old 02-09-2018, 01:36 PM
  #354
Sharkey's Avatar
the mounts will be causing most of the vibrations, i had a set of urethane mounts in my car when i bought it and it was terrible, would rattle your teeth during acceleration.
Old 02-09-2018, 01:55 PM
  #355
My adjustable tensioner was rattling because it was on the wrong setting and the tensioner pulley needs to be replaced. It makes a lot of noise.
Old 02-12-2018, 11:10 AM
  #356
Henry3959's Avatar
Mine does also and I would like to get a ZZP adjuster so I can go to a 2.6 pulley. I put a new idler / bearing on but the OEM's have a lot of movement.
Old 02-12-2018, 11:21 AM
  #357
Henry3959's Avatar
They aren’t backwards. They have a letter F on them for front and they all all facing the front. And those are installed. It’s not top dead center though. And went with what John said. .020 top .025 second and .015 for the oil rings
I'm not going to hit the boost you will but went with .020 / .020 / .018 out of the box. with a .005 piston to wall. I barely had to touch the second rings. First started at .014. That would have been a disaster.
Old 02-12-2018, 12:41 PM
  #358
Some of the rings I got didn’t need to be gapped. And they aren’t all exact. There’s a max and min to them.
Old 02-17-2018, 05:41 PM
  #359
My 80s wot for a couple seconds
Old 02-17-2018, 08:09 PM
  #360
jdbaugh1's Avatar
Can you even overdrive injectors? You probably said it somewhere up in this thread somewhere but you plan on running bigger injectors I assume? Thought you wanted to keep them under 85% or something like that.
Old 02-17-2018, 08:14 PM
  #361
IM Getting my 160s cleaned so I’m having to use my 80s for now
Old 02-17-2018, 09:34 PM
  #362
Sharkey's Avatar
no you cant. 100% duty cycle means they are not closing at all, and thats the max. the computer doesnt see it that way, duty cycle is a calculated figure, the computer used milliseconds in its calculations for fueling.
Old 02-17-2018, 10:30 PM
  #363
Henry3959's Avatar
221 kPa 32 pounds.
Did you tell HP Tuner what bar MAP you have?
Old 02-18-2018, 01:23 AM
  #364
Sharkey's Avatar
you have to subtract barometric pressure when converting to psi. assuming sea level, thats around 17.5 psi
Old 02-18-2018, 10:03 AM
  #365
It hit 23 pounds of boost
Old 02-18-2018, 01:10 PM
  #366
Henry3959's Avatar
Ok... I did the conversion so I have a boost graph
Old 02-18-2018, 02:03 PM
  #367
Slobodan Milošević
07blackg5's Avatar
Old 02-19-2018, 06:21 AM
  #368
jdbaugh1's Avatar
Old 02-19-2018, 05:23 PM
  #369
Henry3959's Avatar
double post
Old 02-19-2018, 05:26 PM
  #370
Henry3959's Avatar
Are you still running the 2.6 pulley?
Is 23 the highest you have seen?
Old 02-19-2018, 05:32 PM
  #371
I’m running a 2.7 and the ati so it’s the same as a 2.6. I’ve only seen 23 so far but I haven’t did a full pull. Haven’t even went to redline. So it probably go to 24-25
Old 02-19-2018, 05:33 PM
  #372
Henry3959's Avatar
That is soooo tempting!
Old 02-19-2018, 05:37 PM
  #373
To get a tvs?
Old 02-19-2018, 06:09 PM
  #374
Henry3959's Avatar
Yes...
Old 02-19-2018, 06:56 PM
  #375
It’s alot funner but not cheap
Quick Reply: Lil Blacky’s official TVS build thread(long post)
