Lil Blacky’s official TVS build thread(long post)
Old 12-22-2017, 04:36 PM
  #126
jdbaugh1's Avatar
Lol me too. Well just the head but I did assemble it in my living room.
Old 12-22-2017, 05:15 PM
  #127
Henry3959's Avatar
[QUOTE=chevygirl2006;7672503]Beautiful
How did the piston to wall clearance turn out?
Old 12-22-2017, 07:56 PM
  #128
chevygirl2006's Avatar
Haven’t measured it yet and the crank does look like that. It’s clean though.
Old 12-22-2017, 07:57 PM
  #129
And we did it in my bedroom. After we are done with the bottom end we are bringing it to the shop to put the head on.
Old 12-22-2017, 08:16 PM
  #130
Henry3959's Avatar
The pistons must just be sitting in there without rings.... since one is backwards.
What did you decide on for ring end gap?
Old 12-22-2017, 08:32 PM
  #131
They aren’t backwards. They have a letter F on them for front and they all all facing the front. And those are installed. It’s not top dead center though. And went with what John said. .020 top .025 second and .015 for the oil rings
Old 12-22-2017, 08:34 PM
  #132
Nevermind I see it. You’re right
Old 12-22-2017, 08:35 PM
  #133
But no big deal because we had to order one more set of rings because one got bent so we are waiting on that
Old 12-22-2017, 08:38 PM
  #134
Henry3959's Avatar
You can't check piston to wall clearance with rings on...
Old 12-22-2017, 08:40 PM
  #135
Well we didn’t really plan on checking. But might as well take them out and check. It didn’t take long to put them on
Old 12-25-2017, 09:07 PM
  #136
FIXed the piston and the piston to wall clearance is .0045-.0048
Old 12-27-2017, 08:53 PM
  #137
Henry3959's Avatar
What's John recommend for the boost your running? .004" is a minimum NA spec. Street / Strip applications up to 15psi of boost usually gets another .001" to .003" .001" to .002" for boosted drag racing depending on piston alloy.
Do you know if your Diamonds are 2618 or 4032?
Old 12-27-2017, 09:10 PM
  #138
diamonds are 2816. I believe i run a .005 ptw or .0055
Old 12-27-2017, 10:23 PM
  #139
Those are the specs he gave me. And diamond also recommends that. They are closer to .0048
Old 12-27-2017, 10:38 PM
  #140
Henry3959's Avatar
This is what I received with my Diamond pistons.
Old 12-28-2017, 09:05 PM
  #141
Henry3959's Avatar
Do you have any plans for manually shifting it? Maybe a nice B&M shifter?
Old 12-28-2017, 09:17 PM
  #142
Na. Just gonna leave it in drive.
Old 12-28-2017, 09:18 PM
  #143
Henry3959's Avatar
That and HP Tuners is what your using fro drag racing?
Old 12-28-2017, 09:23 PM
  #144
Ya and then the line lock and wot box. And messing with the shift pressure. Took a while to adjust the shifting with the shorter drag radials.
Old 12-28-2017, 09:44 PM
  #145
2slo3oh's Avatar
Nice build so far. Glad to see the damage from the hurricane wasn't too bad.
Old 12-28-2017, 10:47 PM
  #146
Ya I got lucky. I thought it was a goner.
Old 01-02-2018, 10:37 AM
  #147
06blackbalt's Avatar
How’s the wot box work on the auto
Old 01-02-2018, 11:46 AM
  #148
Just allows me to press the gas all the way to the floor and it will hold atthe highest rpm the car will go. Since I have a 3k stall the rpms will hold around there. Then the line lock comes in with it so I just release a button and the car launches since my foot is already all the way to the floor.
06blackbalt (01-02-2018)
Old 01-02-2018, 02:07 PM
  #149
Nice I might pick up another auto car soon
Old 01-02-2018, 02:44 PM
  #150
jdbaugh1's Avatar
I'm not familiar with these setups so forgive me if I am missing something but am having trouble figuring out what your WOT box would actually do. Your torque converter will not allow the RPMs to go above 3k given that the engine generates enough torque to get up to 3k. Your engine is putting out all she'll suffer while your brakes or line lock holds the car in place which will preload the transmission. Your torque converter is what holds your RPMS. I always thought you held it at wide open throttle against the torque converter to load up as much as possible but that is just an assumption so I could easily be mistaken. But if that is the case what does your WOT box do? Does it limit the engine torque or preload on the transmission?
Quick Reply: Lil Blacky’s official TVS build thread(long post)
