Limited Slip VS none?
Old Oct 21, 2005 | 03:34 AM
Fingersmoran's Avatar
Loving my black SS/SC but I have to ask, does the Limited Slip help a lot with 0-60 times, or is it more for exiting corners. I am finding that I have problem finding traction launching the car, to much ***** to the walls. I did not order my Cobalt with Limited slip but I think I am regreting it.
Old Oct 21, 2005 | 08:54 AM
UtOhCop's Avatar
The LSD will help a lot off the line and through corner's. GM was retarded for not making an LSD standard on the SS.
Old Oct 21, 2005 | 09:02 AM
CobaltBurst's Avatar
a bud of mine a mechanic at gm "the SS really doesnt have enough power to make the LSD work as intended" and i believe it slows the car down, or hope it does, considering the one i drove with lsd was not impressive.
Old Oct 21, 2005 | 09:20 AM
codyss's Avatar
The power is making taking off hard, the only place LSD is any benifit is when powering out of very tight corners on a race track.
Old Oct 21, 2005 | 10:48 AM
epiphany's Avatar
I think it was motor trend that did a write up comparing the ss and the srt-4 and they noticed that even with the lsd the ss would still spin the inside wheel while cornering.
Old Oct 21, 2005 | 11:06 AM
c7015's Avatar
there is soo much mis-information about the LSD it makes me too frustrated to even post in this thread ...its not that big of a deal unless you cant control your right foot wile cornering ...
www.howstuffworks.com look up how lsd work ..you will then understand how they are beneficial
Old Oct 21, 2005 | 03:37 PM
pmerritt's Avatar
umm right off the line putting power down to both wheels instead of one.....traction benefits of such a setup. i think you'd be naive to not understand the benefits of a LSD. It may not make a hage difference but i am sure it helps.
Old Oct 21, 2005 | 04:00 PM
c7015's Avatar
it will send the power to the wheel with the most traction ....in a straight line i.e. drag race the surface condition is likely identical thus both wheels have the same traction I don’t see a huge benefit, there is however more drive train loss with a LSD
Old Oct 21, 2005 | 10:46 PM
VaMP's Avatar
Cornering and acceleration in 1st gear around slow speed corners that you explode out of is nearly impossible in the Cobalt SS non LSD.... I'm looking into having it installed for the sake of SCCA....
Old Oct 21, 2005 | 11:21 PM
alleycat58's Avatar
Yeah, the LSD is a must-have if you autocross.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
z28addiction
Sep 28, 2015 12:03 AM
grampss
Sep 27, 2015 08:51 PM
